Bluetooth
I have an LG 43UR80006LJ TV. Because of hearing difficulties, I generally use bluetooth iphone earpods headphones when watching the TV.  As far as I have been able to determine, there appears to be no way to use the headphones and also have the TV speakers working at the same time. This means that if I'm watching TV, no one else can watch and listen unless they have headphones.  Am I missing something?  Is there a way to have the headphones and TV speakers working at the same time? Thx
3 answers to this question
    • By JamesH
    • By Fredrik Andersson
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Kane Murphy
    • By janisad
      I have an LG 32LJ610V TV.
