Autostart app on TV switch on
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By Tronner
I don't believe this is currently an option so forgive me if I'm wrong. But it we oukd be great to have an option to switch between bright room and dark room modes at a user specified time. My room is dark at night but fairly bright during the day. So, I'd love to have the option to switch modes at a defined time, much like a blue light filter on a phone. I want bright mode from 7am to 8pm and dark from 8pm to 7am, etc.
Aside from that I'd like to be able to turn the remote mouse off completely if desired.
By SFrank
Actually , i get signal from my nintendo switch on the tv, but i struggle to add configuration with Universal remote menu , the gaming console option is not showing up in the menu.
i saw a lot of advice using device connector app, but unfortunately it seems this app doesnt exist anymore on most recent firmware.
I dont understand what im doing wrong.
edit: i think i m confused with auto device detection & remote configuration. My nintendo switch was not tagged automatically as a gaming console nor named properly but i could change it manually. Then for the remote i m pretty sure there is no ir receiver on the switch itself so …
By Paul Griffith
When I try to go to a TV programme via the remote control voice option, the TV tries to look up the channel on the app I'm on, instead of going straight to the TV channel on the antenna. This used to work without any problems up until a couple of days ago. Any help appreciated.
kongo09
I use an IPTV app to watch TV and would like it to start automatically when the TV is switched on. The TV insists switching on with the not working cable TV tuner.
This is WebOS 5.5
