help) LG tv area option for region change doesn't go back to CA/US from EU
Posted (edited)
Please Help. I have LG qned tv with webOS 23
1) What I did: with svc remote -> in start -> 0413 and all, area option was changed.
I was trying many numbers to find the code for KR (which didn't work).
2) What I wanted : change area option from CA -> KR (widely known area codes do not work)
Original code: CAD 22411
3) Problem: Once I put a number between 19461 ~ 19489, Language&Country is set to EU and would not change the country with the other numbers.
  • Area option: 19461 ~ 19489
  • Continent index: 5 ~ 33
  • Language & Country: EU
Now I put 22411 to change it back to original region, but the country would not change from EU to CA, the area option is back to 19461.
If anyone is trying the area option numbers, don't put any number between them.
If any one knows how to resolve, please help me to escape from EU.. I am so desperate.
FYI just in case
hk 17930
hk 17935
co 17560
ph 15670
cn 17816
ja 17211
aj 17083
tw 17432
pa 17679
hn 18618
ca 18362
mx 18456
hn 18584
br 18789
cl 18876
pe 19033
ar 19123
ec 19251
jp 19345
Edited by whaleandtuna
remove the pic
      Driven by the rapid advancement of AI technologies, the data center construction market is expected to grow continuously over the next decade and possibly beyond.* AI data centers, with their intensive usage of high-powered chips, place greater demands on electricity and water resources and produce more heat than conventional data centers. For these reasons, energy-efficient thermal management solutions have emerged as critical infrastructure components for AI data centers – essential for keeping their servers at the optimal temperature and for minimizing their environmental impacts.
      Conventional data centers typically utilize cooling towers to control internal temperatures. However, this method consumes large amounts of water – an increasingly critical concern given the growing threat of global water scarcity. A report from the World Resources Institute highlights that 25 countries currently experience extreme water stress each year, a number projected to double to 51 by 2050, impacting approximately 31 percent of the global population.
      In response, AI data center operators are turning to more sustainable, water-efficient cooling solutions. Technologies such as air-cooled chillers (ACC) and direct-to-chip (D2C) cooling solutions are gaining traction as smart alternatives that minimize water usage without sacrificing performance.
      At the
      link hidden, please login to view in Washington, D.C., LG showcased its latest lineup of sustainable cooling solutions. Leveraging its deep expertise in HVAC technology, LG is helping to shape a greener future for the data center industry.
      An integral part of LG’s comprehensive suite of data center solutions is the ACC, which employs high-efficiency core components and low Global Warming Potential refrigerants to deliver a remarkable performance with fewer emissions and lower energy consumption. Available in both inverter screw and oil-free centrifugal types, the innovative ACC offers enhanced cooling capability with its “free-cooling” system that leverages a pumped refrigerant economizer to cut down on energy and water use.
      LG has also introduced highly efficient D2C cooling solutions, such as its Cold Plate. When combined with an ACC, this solution is capable of implementing targeted heat removal to help reduce water usage. The system attaches directly to server chips, using a liquid coolant to absorb the heat and channel it through a closed-loop system managed by the Coolant Distribution Unit (CDU). The CDU features AI virtual sensors for full redundancy and boasts a compact, modular design for easy maintenance and installation.
      To create the next generation of data center cooling solutions, LG opened a dedicated AIDC testing facility earlier this year at its LG AI Data Center HVAC Solution Lab. The lab is capable of conducting real-world simulations of data center environments, helping LG fine-tune its systems to meet evolving customer and environmental demands.
      Through its ongoing research and innovation, LG is reinforcing its position as a global leader in sustainable data center cooling. By delivering solutions that cut energy use, reduce water consumption and maximize performance, LG is committed to supporting both the future of AI and the health of our planet.
      * According to , the size of the global data center construction market is estimated at USD 258.56 billion in 2025 and is forecasted to reach around USD 491.99 billion by 2034, accelerating at a CAGR of 7.41 percent from 2025 to 2034.
    • By garamja
    • By Luka Pantsulaia
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By John Nguyen
