Playing a Radio Channel using Alexa
By hollean
By JamieG
By Nihar Ranjan Dash
The international content on JioCinema and Hotstar apps are not playing. No issues with Indian content in Hindi or other regional languages. But English, Korean, and Japanese content are not playing. Specifically, I want to play Disney content on Hotstar and HBO content on JioCinema App.
I tried resetting all configurations and reinstalling the applications and re-logging into the apps. Still, the issue persists. I tried switching off the TV and tried pressing the power button for complete discharge and rebooting my router, but the same issue persists.
**I found a workaround though, changing the wifi network or using a mobile hotspot on TV and then all content plays well even if I revert to my primary Airtel wifi, It still plays. but the next day the same issue continues.
It's an overhead to switch the wifi every time I want to watch Hollywood titles. Certainly, it's not the experience I want with a TV of a hefty price tag. No other devices (Mac, ios, android, windows, Android TV) have this problem. Also, it's not the wifi issue, as I can watch the same titles on other devices. The LG TV also doesn't have the capability to remember a few WiFi networks to ease this workaround of switching networks.
Alas, Nobody informed me about this issue earlier while making the purchase. Now such pricey TVs shouldn't have these issues at all. Kindly let me know If there is a permanent fix for this issue.
By manish_
Hello, I am looking for an app through which I can play videos on USB because inbuilt media players do not support all formats. And in some videos I'm facing frame drops or lagging.
By leodavid
I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
The buttons work fine but for some reason, I can't get the cursor to appear on screen.
Appreciate the help. Thanks
Citron2010
Hi, I have an LG 43UN71006LB with OS v4.50.53 (latest)
I thought I'd test this on my TV and it works very well. I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
Also tried:
"Alexa, enable Sound Share on LGTV" - "that command doesn't work on device LGTV"
Anyone have any ideas?
