App Review dots lines and squares
Sometimes you just need a quick classic game to fill some idle time in your day. In the old days you'd grab a piece of paper and set up the four lines for tic-tac-toe, or if you were feeling particularly ambitious you might lay out a grid of dots for a game of dots-and-lines. Thanks to the magic of tablets, you can make a quick game tic-tac-toe happen, or if you're in that particularly ambitious mood you can turn to
for the paper classic.
a2t.imgrIZ2hJhAKz8
    • By Virus17
      Hi all, I have this 4K LG 49UF772V TV which has had this issue since I bought it second hand and I'm wondering if anyone has any idea how it can be fixed as I am looking to sell it.
      The issue: On the LG menu and main home screen + sub menus and programs such as Netflix, there are black squares all over the display which makes it impossible to use. However, the TV works flawlessly when using the display with a HDMI device connected.
      I suspect this could be either a software issue since there's no physical defects with the display itself. The TV has the latest software update running (04.06.25). I've attempted to reflash it and downgrade it but I haven't managed to find a way to do it.
      Also note that only 1 of the 3 HDMI ports work. The other two gives no output when a device is connected.
      I have also carried out a factory reset and this has not made a difference.
      I have attached a short video showing the TV connected to chromecast and the display working as expected and then pressing the settings button yields artifacts/small black squares. + some pictures showing this.
      Thank you in advance!
      LG_49.mov
    • By Alex
      the viewer sits.
      Source:
    • By ken325i
      Need some help with my 55B6.....can't get the firmware to update......I have 3 spinning dots!!
      Here is what has happened.....
      - When watching I was getting the screensaver fireworks for no reason
      - As done in previous situations, I triggered "reset to initial settings".
      - the 3 colored spinning dots were triggered as if the reset had started, but no reset occurred.
      - the 3 colored spinning dots would not go away.
      - I downloaded the firmware to USB and tried to update using the manual USB update process per LG's online instructions.
      - When I turn on the TV, with USB inserted, I still get the 3 colored spinning dots -- NOTHING HAPPENS!
      I have tried 2 different USB drives and formatted both to FAT32, no success.  Can't get past the 3 spinning dots!
      Don't know where to go with next step!!
      Thanks for any help you can provide!
      Ken
    • By John Magann
      On certain scenarios, I notice barely visible Elongated rectangular lines on the LEFT side of my screen?
      Please advise
      John M.
    • By Kartengall
      In the middle of our LG WebOS fernserher is a gray circle with rotating colored dots, whenever Live TV or media library is viewed.
      At Netflix, the problem is not!
      Is the TV looking for something here?
      Thank you very much
      Thomas
