At Europe’s Largest HVAC Exhibition, Company Introduces Highly Energy-Efficient
Residential and Commercial Solutions Designed to Deliver Optimal Indoor Comfort
SEOUL, Mar. 11, 2024 — LG Electronics (LG) is presenting its latest heating, ventilation and air conditioning (HVAC) solutions at Mostra Convegno Expocomfort (MCE) 2024 in Milan, Italy, from March 12-15. LG’s booth will showcase the company’s energy-efficient HVAC solutions for home and business, including the new DUALCOOL™ residential air conditioner indoor unit that provides a year-round pleasant indoor environment, residential heat pump solutions and commercial hydronic solutions employing low-Global Warming Potential (GWP) refrigerants.
New Residential Air Conditioners With Comfortable Air Flow
In the Home Gallery section of the booth’s Residential Zone, visitors can see for themselves what is so special about LG’s new DUALCOOL residential air conditioner with ‘interior fit’ design.
LG’s air conditioner is equipped with a comfort-enhancing Soft Air™ function, which provides customized and a soothing, indirect breeze, and an innovative DUAL Vane™ system, sending warm or cool air in multiple directions to deliver fast and effective temperature control for a favorable indoor environment. Engineered for the European market, the DUALCOOL leverages the state-of-the-art DUAL Inverter Heat Pump Compressor™ to deliver efficient heating and cooling. Another feature designed to reduce energy consumption is the kW Manager™, which lets users set electricity-usage targets and monitor the air conditioner’s estimated electricity usage via the ThinQ™ app.
Also on display in the Residential Zone, the stylish ARTCOOL Gallery™ air conditioner can be personalized by selecting beautiful images or dynamic content (using the ThinQ app) to display on its bright LCD screen, which is bordered by a simple yet sophisticated frame.
Residential HVAC Solutions for Diverse Installation Environments and Lifestyles
The Air-to-Air Residential Solution area of LG’s booth offers up a wide selection of solutions from the Multi Split lineup, including the new wall-mounted DUALCOOL residential air conditioner and several indoor units that can be adapted for diverse installation environments and lifestyles. Additionally, visitors can check out the company’s residential Variable Refrigerant Flow (VRF) solution for residential applications such as Multi V™ S combined with Hydro Kit (Integrated Water Tank). This seamlessly integrated innovation provides stable heating, cooling and hot-water supply.
In the Air-to-Water Residential Solution section, the spotlight is on the LG Therma V™ R290 Monobloc air-to-water heat pump (AWHP) and an array of medium- and large-size heating solutions. Ideal for use in single-family residential dwellings, the R290 Monobloc matches strong performance with an equally strong design – one that incorporates an elegant and wavy grille finished in matte black. Among the various indoor and outdoor units on display in the Air-to-Water Residential Solution section are the Control Unit, Combi Unit and Hydro Unit – a diverse lineup that is compatible with R290 Monobloc, demonstrating LG’s unmatched ability to provide solutions for diverse installation environments. Moreover, the high-efficiency heat pump solutions are available in various capacities to meet the needs of both new and existing residential properties, including multi-family dwellings.
Home Energy Platform for a More Sustainable Solution
Inside the Air-to-Water Residential Solution section of the booth, visitors can learn how LG’s Home Energy Platform can create a more sustainable solution for home. An extensive energy solution that brings together the LG Therma V R290 Monobloc and the Energy Storage System (ESS), the Home Energy Platform streamlines HVAC and energy management, and can help shrink a household’s carbon footprint.1 Moreover, the heat pumps can significantly reduce carbon emissions when coupled with renewable energy sources such as solar.2 The ESS offers innovative ways to improve the efficiency of renewable energy usage in the home, and functions as a back-up power source if electricity supply is interrupted. Furthermore, the Home Energy Platform is compatible with LG ThinQ Energy,3 an extensive feature of LG ThinQ app, enabling users to monitor energy storage consumption and control their smart appliances and HVAC systems from their smartphones.
Advanced Hydronic Solutions Headlined by the Multi V™ i
In the Commercial Zone, the focus is on advanced hydronic solutions like the Multi V i, Inverter Scroll Chiller and select Hydro Kit lineups. The Multi V i leverages LG’s AI Engine to deliver AI Smart Care, which uses spatial and situational learning to help reduce daily energy consumption. Consistent thermal conditions are essential to accommodate optimal temperature preferences and ensure user safety and peak performance. The AI Indoor Space Care automatically adjusts the indoor environment in response to actual conditions, regulating connected indoor units to provide a convenient user experience and maintain a steady temperature. Another feature enabled by the AI Engine is AI Energy Management, which allows users to set energy consumption targets to lower the overall power usage of Multi V i.
The Commercial Zone also features LG’s innovative heat recovery unit, designed to enhance the safety of R32-refrigerant-equipped HVAC solutions. In addition, the zone highlights VRF solutions for light commercial spaces, alongside the R32-refrigerant Multi V and Inverter Scroll Chiller.
What’s more, visitors to LG’s booth can experience the airflow of DUALCOOL and 4-way Cassettes via the use of Augmented Reality (AR) and kinetic visualization technology. LG’s industry-leading HVAC component solutions, including its efficient and durable compressors, will also be on display during the exhibition.
“LG’s cutting-edge residential and commercial HVAC solutions on show at MCE 2024 provide a comfortable indoor environment, exceptional efficiency and smart, convenient control,” said James Lee, head of the Air Solution Business Unit at LG Electronics Home Appliance & Air Solution Company. “We will continue to deliver optimal indoor comfort in both residential and commercial environments through high-efficient solutions, employing precise airflow control technology and core compressor technology.”
Visitors to LG’s booth (#U28/Z16, Hall 5, Fiera Milano) at MCE 2024 can experience and explore the company’s full portfolio of innovative HVAC solutions.
1 Therma V R290 cuts carbon emissions by up to 93 percent compared to a conventional boiler by using heat from the air as an energy source. Carbon emission rates are calculated for space heating only. Using EN14825 climate data and assuming 4,910 annual operating hours with 35 degrees Celsius temperature operation based on average temperatures in France. Calculations based on June 2023 energy prices and the carbon intensity of the power sector in the EU in 2022, and 56.1 t-CO2/TJ is considered for calculation of CO2 emission of gas boiler.
2 According to the German Heat Pump Association, the annual CO2 emissions of heating systems vary significantly based on the power source. When a heat pump is powered by renewable energy, the emissions are as low as 0.09 tons, the least amount recorded, while using heat pumps powered by conventional energy results in emissions of 1.35 tons. (Exemplary figures from Germany, 2020; 4 persons, 200m2 flat and sourced from German Heat Pump Association, waermepumpe-bwp.de/co2-neutral-heizen/)
3 ThinQ Energy is an extensive feature of the LG ThinQ app. The name of the app and feature availability may vary depending on model and region.
      LG has once again left a lasting impression on visitors to ISH, one of the world’s biggest annual tradeshows for HVAC, water and sanitation solutions. Held in Frankfurt, Germany, the event highlighted LG’s extensive range of integrated heating solutions customized for diverse environments and spaces, including high-efficiency residential heat pumps and large-capacity commercial systems. Tailormade for the European market and compliant with the European Union’s F-gas Regulation, LG’s products exclusively employ refrigerants with a low Global Warming Potential (GWP).
      A major attraction at LG’s booth, the Hero zone introduced ISH visitors to the exceptional Therma V R290 Monobloc air-to-water heat pump (AWHP) for residential applications. Displayed beneath a captivating hanging façade at the center of the zone, the new Therma V boasts a sleek, minimalist design, quiet operation and outstanding cold-climate performance, thanks to LG’s advanced scroll compressor. Designed with user comfort and the health of the planet in mind, the Therma V employs R290 refrigerant, which has a GWP of 3, to reduce carbon emissions.
      LG also showcased the Monobloc G and Cascade Control Unit, two sophisticated solutions suitable for multi-unit apartment buildings and large homes. The Cascade Control Unit offers flexible scalability, allowing users to add up to eight outdoor units to their HVAC system. This adaptability not only meets varying heating demands but also optimizes energy efficiency, thereby contributing to the reduction of HVAC running costs.
      Another notable exhibit was the new LG heat pump water heater (HPWH) with R290 refrigerant. Displayed in a booth area designed to resemble a stylish European kitchen, the versatile HPWH R290 utilizes both air and electricity as energy sources, achieving greater efficiency than traditional electric or a gas-powered water heaters. Its simple design ensures compatibility with various installation environments and customer needs, offering seamless integration with various types of indoor units, such as control, hydro and combi.
      In response to recent EU restrictions on refrigerant usage, LG has launched a complete lineup of reliable commercial HVAC solutions utilizing R32 refrigerant (GWP of 675). Visitors learned about the innovative, large-capacity Inverter Scroll Chiller, which leverages twin inverter scroll compressors to maximize cooling power and operational efficiency. The Inverter Scroll Chiller can be integrated with LG’s Building Energy Control (BECON) CPM system, which utilizes advanced AI technologies to simplify control and monitoring of LG’s commercial HVAC solutions.
      The Multi V i R32 variable refrigerant flow (VRF) solution was another attraction at LG’s booth. Incorporating the company’s AI engine, the Multi V i intelligently manages temperatures across multiple indoor spaces. This VRF solution includes a full package of integrated solutions, including a number of safety features and systems designed to enhance stability and reliability, and provides time-saving troubleshooting assistance with Smart Diagnosis.
      LG, a pathfinder for innovative heating, has been at the forefront of HVAC innovation for several decades and continues to show the way forward. With its comprehensive exhibit of efficient and sustainable HVAC solutions at ISH 2025, the company reaffirmed its commitment to decarbonization and to paving the way to a better future for all.
    • By OliverRC
      LG Recognized in the Automotive Category of This Year’s List for Driving
      Mobility Innovation With Its Advanced SDV and In-vehicle Technologies
      SEOUL, March 19, 2025 — LG Electronics (LG), a global leader in mobility technology, has been named to Fast Company’s The World’s Most Innovative Companies of 2025 list in the automotive category, announced on March 18. This recognition highlights LG’s strong performance and continuing success as a pioneer of software-driven mobility solutions.
      Fast Company, one of the world’s preeminent business media brands, has published The World’s Most Innovative Companies list every year since 2008. The list acknowledges organizations that have made a meaningful impact through their commitment to innovation, ranking the top-performing businesses across 58 industry categories.
      A trusted mobility partner, LG is making rapid progress in the pursuit of its bold “living space on wheels” business direction, which reimagines the traditional automobile as an intelligent, connected environment. The company’s seamlessly integrated infotainment systems, displays, telematics and AI-powered technologies enhance safety and comfort for drivers and passengers, while also bringing the personalization and convenience of the smart home to the in-car experience.
      LG is realizing its futuristic vision through advancements such as the AI-powered in-cabin sensing solution, designed to make vehicles more intuitive and responsive to their occupants’ needs. Employing Vision AI and an array of sensors, LG’s solution monitors the heart rate, facial expressions and attentiveness of the driver and passengers in real time to assess their physical and emotional state. By detecting whether the driver is fatigued, stressed or distracted, and providing appropriate cues or reminders, it can help improve road safety. The company’s sophisticated sensing solution also offers personalized driving routes, real-time traffic updates and smart in-cabin adjustments.
      Being named to Fast Company’s The World’s Most Innovative Companies list follows a year of major successes for the LG Vehicle Solution (VS) Company. In 2024, LG introduced a cross-domain platform integrating Advanced Driver Assistance System, Automated Driving and In-Vehicle Infotainment systems to provide a flexible, cost-effective solution for OEMs. It also expanded its webOS-powered Automotive Content Platform to give vehicle passengers more immersive entertainment options. Additionally, the company launched LG AlphaWare, a comprehensive suite of software for software-defined vehicles (SDVs), and earned global recognition for the security and safety of its V2X technology.
      “We are honored to be included in Fast Company’s list of The World’s Most Innovative Companies of 2025,” said Eun Seok-hyun, president of the LG VS Company. “As a leading driver of future mobility innovation, we will continue to create cutting-edge SDV technologies and AI-powered solutions that transform the in-vehicle experience and improve road safety.”
    • By Batman
