App Review Tallier
There's something to be said for playing a real physical board game. The feel of the dice, the satisfaction of moving your pieces, being able to ponder the board in front of you and how best to proceed. But there's something that's not so satisfying: keeping score on a sheet of paper. But, as they say, there's an app for that:
. Made by Ewac Software, Tallier is a basic score tracker at its core, but it offers much more beyond a simple tally.
a2t.imgJSKTUoKRy48
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
