The internet connection to the YouView box does not reach down the HDMI cable to the TV, even if that cable has the Ethernet strand.
You should however be able to connect the TV to the router via WiFi, or via another Ethernet cable, which ever is most convenient for you.
The dialogue will be under Network in Settings, the gear wheel symbol on your remote (give it a long press so that it opens up completely); on my LG C2, Network is then under General, but it’s under Connections on my GX, so you may have to look for it in the Settings.
Then you just have the normal WiFi dialogue, SSID and password, as when setting up any device on your WiFi.
I did dig out a manual online for your TV; it confirms the TV has WiFi, but oddly, there doesn’t seem to be a section on setting it up. Maybe this is in the Quick Start/First Setup guide?
Anyway, it should be easy to do. And once you have done this, the Browser app will work, and likely all the other apps along that row, like the BBC iPlayer and so on.
    • By Wondering
    • By Maria D
      How to change view from 16:9 in movies to fit full screen
      LG QLED B22
    • By Kemal Sözüner
      I recently bought a LG TV with WebOS version 8.1 and have a frustrating issue.
      I have a usb disk with all my family photos & videos archive in it.
      We love to browse through the pictures and videos on big screen.
      But current LG TV media player displays either pictures or videos. I want to see them in the order they were captured.
      It would be great to enable this feature when "Photos & Videos" filter is selected.
    • By Kemal Sözüner
      Is there a way or another app to view photos & videos at the same time? (slideshow)
    • By dbradford
      Hi all, im trying to use multi screen function (just found out about this) - does anybody know if this specific tv has multi view function? I cannot find it anywhere in settings so didnt know if im being dumb and cant find it, or if it isnt actually on this tv model. Thanks
