Possible To Turn Off Screen When Listening To Youtube Videos ??
hi,
5 answers to this question
On 4/15/2024 at 8:44 PM, Rodf said:
My LG C1 has a screen off button , press the settings on remote. If its not in the list you can edit to find it
i tried the edit function while using Youtube...............doesn't work.............when i click on ''screen off'' button - it says it won't work for certain apps...........i'm using the most budget tv model so maybe that's the reason ?
I have the same problem on my C3 Oled.
While watching/listening videoclips on YT I'm not able tu use function to turn off the screen. I have no problem with my other LG CX but only with C3. Can't find solution. It could be some issue with YT app maybe
    • By DWINKS49
    • By Batman
    • By Lee Magee
    • By Will M
