Disable G2 bluetooth
By mycop
Greetings.
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
curious george
Hi, I'd like to disable the bluetooth on my G2 and was wondering if this was possible without having to disconnect the bluetooth module in the back?
