LG TV remote DLNA access via VPN
By RJ Fischer
By Lorenz
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
