55SJ850V USB files for updated
By mahdi alborzi
I need to update this TV
Model : 55SJ850V-TA
Serial number : 707CGKWMJ215
ESN : LGTV20171=11001816919
VSN : 1F580793
Widevine: LGTV17CLGE002389488
By Jimout
I am getting a "cannot download files" when I try and download a FirePro file.
I was able to download before.
Is there a way around or fix.
By Kevin_Idaho
Our LG TV was just updated with the latest software - before when the TV was turned on it was set to the previous input (one of the HDMIs). Now it appears to be sent to the Home Dashboard and I have to manually change it to the desired HDMI input. Does anyone know how to fix this? Thanks!
By David J
Hi all,
My LG OLED55E7N just updated to firmware 06.00.25. I must have wronged the god of Google, because I fail to find any whatsnew. Anyone?
Thx
By Nova1545
I have a 55UH6150 LG Smart TV and was wonder if it was possible to update it to version WebOS 6. I have some apps I would like to install but sadly they are only avaible on the content store from WebOS 6+. Is it in anyway possible to update the SW for it?
I know the page doesn't show WebOS 6 listed for it, but am curious if there is a way I can do it anyways
Any information would be much appreciated
mahdialborzi
از درگاه وای فای بروزرسانی نمیشود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
لطفا کمکم کن ید
