Can’t turn on TV with Alexa
By u84six
By Low Grade
hi,
By yippie_kiyay
My new LG TV (65UM6900PUA) running WebOS 04.71.25 works great with HomeKit, with the exception that it is not reachable while it is turned off. If I try to turn it on in the home app, it says "No Response." I have changed the 'Turn on via Wi-Fi' setting to on, and it will turn on from the 'LG TV Plus' app, but not from the iOS home app. Is there a specific setting or something I need to change?
By Cihanimus
By bos2prov
Trevin
