  • 11 months later...
    • By Cody94549
    • By toopie28
      Hi can someone help please.
      Not sure what else to try.
      Thanks!
    • By Batman
      I have a LG 43QNED756RA AEK Smart TV
      If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
      So I cannot Move or Edit Program Numbers or Delete
      Any help and comments would be appreciated
    • By pattox
      It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose  the + add item.  If you want to add a "shortcut" to an item that is not on the list then how can that be done.  Is it possible to edit the list presented?
      Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings,  there nothing on the list of options presented to allow this.
    • By kerbe
      I have six Sonos smart speakers in my home and WebOS recognizes them all as Media Servers, making it necessary to scroll to find the ACTUAL Media Server. Is is possible to set WebOS to NOT recognize the Sonos speakers as Media Servers?
