Annoying problem on certain BBC programmes
By Venkata
Hello Team,
By PVD
By hollean
By AJO
By JamieG
Birkso
Have an LG55Nano which works well apart from when on specific BBC shows whereby whenever there is a switch if camera, say from contestants to host and vice versa, there is an extremely annoying flickering motion that takes place. May sound petty but any visitors comment on how distracting it can be.
Happens constantly on Richard Osmans House of Games, Impossible, Pointless and similar BBC programmes. Reported it but was told I had to get video clips for them to assist despite it being less than a year old. Life's too short. Any advice very welcome.
