Recently live channels stopped working with an error every 2-3 seconds.
Older media is still playing.
Now I noticed that new media like today's news aren't playing either. Same error.
News from Friday 3rd may still work.
Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
    • By John Nguyen
    • By Nick Payne
    • By Trollpaw
      Hello.
      I have an issue with my tv losing connection.
      It seems like it's not uncommon for it to happen from time to time. but is has gotten worse the past couple of months. It can happen several times per day. usually when using netflix, but it can happen whenever.
      i regularly lose the bluetooth connection to my magic remote, and a lot of the times when this happens i also lose connection with the wifi, The remote is still usable, in a somewhat limited capacity(no pointer, and need to have a more clear line of sight to the tv)
      when the wifi disconnects it sometimes connects automatically, sometimes i have to manually connect it again, and sometimes the wifi function gets turned off, and can't be turned on again. usually this solves itself by putting the tv on standby and starting it again. using cable instead of wifi is not possible for the moment.
      the remote. what usually works is pulling the plug on the tv for a while, and then it functions again. sometimes it's enough just putting it in standby mode for a minute or 2. sometimes i have to unregister and re-register the remote. THere's not one thing that works all of the time, so i have to try several things, but i've found that pulling the plug usually works best.
      it's rarely enough to un-register and re-register the remote, i usually have to either put the tv in standby for a couple of minutes, or pull the plug
      it's getting very frustrating dealing with this, so i'm asking to see if anyone knows what to do as a more permanent solution. i have no issue with doing factory resets or anything like that.
      Regards
      Stoffe
    • By Ajay Lele
      I shifted to India from UAE with my 55SM9000PVA LG TV. Since it is a TV for the middle east, I can not change the region to India. Therefore I can not log in to my LG account and have apps from the LG content store of India. Ok, so I thought I should be able to use my account in UAE and use the apps which I used in UAE. Now these apps say the IP address is not from the region, so can't run those apps. So I am stuck up with an expensive smart TV without smartness. No service center, neither LG India have any answers to it. I hate using set top boxes please help.
    • By Berb
      good morning forum,ihave been tryig to download 3rd party apks onto  my LG Smart Tv but all i get is file not supported ???????
