How to delete a Kodi backup
By maninblack2000
I used the developer mode method to put Kodi on my TV, everything seemed to go to plan and it is there on the home screen but when I click on it it opens then closes again, does anyone have any idea why that is?
By Davidof
I would to find an app like kodi
a médiathèque that could search all my movies ( on the network ) scan it and find all information about the movie orignal title picture … ) and make wall of all the movie.
to you know a app like thise ?
thx.
By Tomasz Maciążek
Any chance to get KODI to work on WebOS
I want to connect to my NVR cameras and local TV broadcasts
By coyote
Is there any way to delete the preinstalled apps? I particularly hate the "LG Channels" app because if I were to click the Antennae input inadvertently, something on one of those channels could cause burn in. -
By Marcelo Richard Valverde
I started building a client for Kodi that runs on Smart TV LG webos.
As a client, need a Kodi server running on local network to consume the JSON-RPC API.
Communicates through websockets.
It is being implemented in Javascript using REACT JS.
I'm looking for developers for the GUI.
Contributions are welcome!!
see the project on github:
fmas2
Hi everyone,
I´ve installed Kodi on LG WebOS. I need to delete some backups that by default are stored in the WebOS root system. I guess it can be done through WebOS Dev Manager but I´ll appreciate any help giving me the path to achieve such backup folder.
Many thanks in advance
