PreCentral: Monday Brief: NFC hacking on Android, Guide to Siri, Windows 8 SDK preview and more!
Mobile Nations
A little change this week for the Monday Brief as our normal host, the adventurous Ashley Esqueda, is off in London right now taking in the London 2012 Olympic Games. No, you'll not see her on any diving boards or dressaging any horses herself but you can check her adventures on the her
page. The show as they say though, must go on so go ahead and check out what's been happening around Mobile Nations below.
a2t.imgd3x-KJhIiYw
    • By Peter_T
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
    • By Den C
