DLNA client problems since last update
  1. When I'm using the DLNA client to select videos from the server, I get no response from trying to select a video or series using the remote. The remote continues to work fine when used with other apps (eg Netflix, Stan etc) on the TV.
  2. When the DLNA client is playing a video from the server, the audio is delayed by a couple of seconds from the video.
At the time that the TV is showing either of these problems, I can access the media server using either BubbleUPnP on my phone or VLC on my PC, and neither of them have any problem either selecting videos or playing them back with the audio synced with the video, so the problem is clearly with the TV, and power-cycling the TV gets rid of whichever problem is manifesting itself.
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
