Screen mirrowing does not work
By Horniak
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By CJ Catalano
jeamvangils
We just bought this LG tv1 LG 43UR73006LA (2023).
The screen mirror from my MacBook gives our LG tv as an option but when I click it, it says there is no connection possible with '[LG] webOS TV UR73006LA'
Also when I want to add the tv to my Apple HomeKit, it is not possible.
The TV is on the same WiFi network and I checked if there are any updates available.
What can I do?
