[World Environment Day with LGđ±] LG Hope Screens Promote Restoration for World Environment Day
for AI Data Centers
SEOUL, April 15, 2025 â LG Electronics (LG) is unveiling a comprehensive lineup of cooling solutions at the Data Center World (DCW) 2025 conference in Washington, D.C., from April 14-17. This marks LGâs debut at DCW, where the company is presenting an array of advanced data center cooling solutions, including high-performance chillers, air- and liquid-based server cooling products, and the LG Building Energy Control (BECON) solution. With its high-efficiency direct-to-chip (D2C) cooling technologies and integrated AI-powered control software, LG aims to make significant inroads into North Americaâs rapidly growing data center market.
AI data centers generate more heat and consume more electricity than conventional data centers due to higher server-rack density and the increased usage of resource-intensive computer chips, such as graphics processing units and high-bandwidth memory. LGâs hybrid solution, which combines chip cooling and room cooling, is designed to meet the thermal management needs of these next-gen facilities, delivering outstanding performance and top-tier energy efficiency. Visitors to the LG booth at DCW can learn all about the companyâs tailored cooling solutions for AI data centers and witness the commitment to innovation that has propelled LG to the forefront of the global HVAC industry.
LGâs exhibition highlights the companyâs liquid server cooling solutions featuring D2C technology; a remarkable innovation that applies cooling directly to the serversâ chips. Leveraging the companyâs high-efficiency inverter pump and heat exchanger, the LG Coolant Distribution Unit (CDU) controls coolant temperature and flow to improve energy efficiency and reduce electricity consumption. Thanks to its compact size and modular design, LGâs CDU provides installation flexibility, enabling a variety of configurations consisting of up to eight units. The CDU has a 10.4-inch touch screen that offers convenient control and supports easy maintenance. Equipped with the companyâs fully redundant sensor system, which features both physical and virtual sensor technology, the CDU ensures continuous operation through the provision of backup operation and sensor-fault prediction diagnosis. Furthermore, the CDU uses LGâs Active Load Sharing technology to track the optimal efficiency point for each load, thus elevating overall system efficiency.
Another LG innovation being introduced at this yearâs DCW is the Cold Plate: a liquid cooling solution designed to be directly applied to the high-powered chips used in AI data servers. The solution is able to manage the high thermal design power (TDP) of these next-generation chips thanks to the low thermal resistance of its advanced design. The LG Cold Plate utilizes a manifold with a parallel coolant supply structure to deliver upgraded cooling performance. The companyâs impressive solution also employs a bottom-mounted Skived Fin to maximize the heat exchange area and boasts a âtwo-wayâ configuration that optimizes the coolant flow path. Moreover, the Cold Plate can be customized according to site- and usage-specific requirements through an AI-powered optimization process that includes a state-of-the-art performance simulator. To minimize the risk of coolant-liquid leakage, LG uses brazing to create the strongest possible bond between key elements, and also subjects each Cold Plate produced to a âthreefoldâ leak inspection.
Optimized Cooling with LGâs Powerful Chillers and Computer Room Air Handler
Used in a variety of industries and known for their powerful cooling capabilities, chillers have emerged as important infrastructure components for AI data centers. LGâs Water-Cooled Oil-Free Centrifugal Chiller provides exceptional energy efficiency via a lubricant-free structure and LGâs proprietary magnetic bearing technology, LeviTech. These innovations, along with a machine learning-based feature that protects against chiller surges, help to reduce energy loss, improve operational reliability, and facilitate fast recovery from unexpected power outages. Designed with sustainability in mind, LGâs water-cooled oil free inverter centrifugal chiller use refrigerants with a low Global Warming Potential.
Available in both inverter screw and oil-free centrifugal types, LGâs Air-Cooled Chiller (ACC) incorporates high-quality core components, such as the companyâs inverter screw compressor, to set new standards for performance and efficiency. Enhancing both cooling capability and system dependability, the innovative âfree-coolingâ mode allows the ACC to switch seamlessly between mechanical cooling (with the refrigerant cycle) and free cooling (without the refrigerant cycle). LGâs next-gen ACC also has a backup cycle that prevents interruptions to operation, and comes equipped with a three-stage oil recovery system that further boosts reliability and safety.
A solution that pairs perfectly with the ACC, LGâs Computer Room Air Handler (CRAH) utilizes electronically commutated (EC) fans and oval coils to minimize electricity usage. The fans use high-efficiency 3D blades along with EC motors that leverage power factor correction to reduce total harmonic distortion in the current. In addition, the CRAH has a compact, modular fan wall unit structure that makes installation and maintenance more convenient, saving customers time and cost. To drive the development of future cooling solutions, the recently established LG HVAC Solution Lab has created a sophisticated testbed that can accurately simulate various usage scenarios and environmental conditions.
LGâs data center cooling solutions, from chiller plants to D2C and room cooling systems, can all be easily controlled through the BECON system. A single, unified solution for managing and monitoring server cooling and chiller systems, BECON can intelligently coordinate each connected cooling solution to achieve and maintain the required temperature and level of humidity. The BECON solution, which can be applied to multiple interfaces within a facility, can also carry out data analysis to maximize the energy efficiency of LGâs cooling solutions, helping reduce the financial burden of the round-the-clock cooling operation that data centers need.
âThe exceptional LG thermal management solutions on show at Data Center World 2025 leverage our latest AI technologies and the considerable insight gained from our partnerships with AI data centers worldwide,â said James Lee, president of the LG ES Company. âAs a leading provider of innovative HVAC solutions, LG will continue pushing forward to deliver efficient cooling infrastructure for North Americaâs fast-growing AI data center market.â
Designed as an All-In-One Gaming Platform, LGâs Gaming Portal Offers Effortless
SEOUL, Feb. 21, 2025 â LG Electronics (LG) is bringing its Gaming Portal to a wide range of screens and platforms in 2025. Currently available on LG Smart TVs running webOS 23 and above in 19 markets,1 the service will extend to additional markets, platforms and devices â including LG Smart Monitors and StanbyME lifestyle screens â by the second quarter of the year. This expansion aims to enhance the overall game streaming experience by providing seamless access to popular and new titles.
Designed for seamless access through the Home Screen, the Gaming Portalâs simple interface provides an intuitive way to browse and enjoy games without the need for external consoles or devices. Users can navigate a curated app list that includes cloud gaming apps, webOS app games playable with the remote control, recently played titles, the top 10 trending games, editorâs picks and other personalized user-friendly gaming options.
Players can quickly find their preferred gaming experience by selecting either âPlay with Remote Controlâ or âPlay with Game Padâ from the left-side menu, eliminating the need to search through individual games.
For a personalized experience, My Page acts as a central hub for tracking achievements, earning badges and more.2 Gamers can see a comprehensive summary of their progress, points, levels and tier upgrades based on their activity within the Gaming Portal, enriching their overall gaming journey. The My Games menu of My Page also allows users to create a personalized game list tailored to their interests, so they donât miss out on their most anticipated titles.
Enhancing the gaming experience further for PC or console games, LG TVs support 4K at 120Hz variable refresh rate (VRR) for fluid, tear-free gameplay and boast NVIDIA G-SYNCÂź Compatible and AMD FreeSync Premium certification.
Whatâs more, taking its reputation as the ultimate choice for gamers, the latest LG OLED evo TVs, boast the industryâs first 4K 165Hz3 VRR and are the first to receive ClearMR 10000 certification by VESA, for a flawless motion during fast-paced action.
LG is committed to bringing an elevated gaming experience to its screens powered by webOS, delivering an array of content and services and an intuitive interface for more versatile gameplay. To learn more about LGâs ongoing journey to enhance the user experience with its Gaming Portal, visit
Company Showcases Future of AI-Powered Customer ExperiencesÂ
Through CEO Keynote and Immersive Storytelling Â
LAS VEGAS, Jan. 6, 2025 â LG Electronics (LG) unveiled its vision for AI-powered customer experiences themed âLifeâs Good 24/7 with Affectionate Intelligenceâ at the LG World Premiere event in Las Vegas on January 6, the eve of CES 2025, widely regarded as the worldâs most influential tech event. Â
Over 1,000 attendees, including global media and partners, were present at the press conference, which was also livestreamed online. To showcase the full scope of LGâs Affectionate Intelligence-powered customer experience, the event stage was divided into three areas representing the various spaces in peopleâs lives, from the home to mobility and commercial spaces. The company, through engaging demonstrations highlighting real-life scenarios, made clear how its advanced AI will transform daily life for the better.Â
LG âAffectionate Intelligenceâ is redefining the conventional, technical understanding of AI by focusing on its potential to revolutionize the customer experience paradigm. This concept leverages AI technology to better understand and empathize with customers, delivering more personalized and differentiated experiences. Â
The LG World Premiere kicked off with a video titled âLess Artificial, More Human,â followed by a keynote speech delivered by LG CEO William Cho.Â
âAt LG, weâre seamlessly integrating AI into physical living spaces around us. We see space not merely as a physical location but as an environment where holistic experiences come to life â across the Home, Mobility, Commercial and even Virtual spaces,â said CEO Cho. âIn these spaces, devices and services will harmonize to create entirely new customer value. This is where our Affectionate Intelligence truly shines, clearly standing out from the others.âÂ
Cho then highlighted three fundamental elements to realize this vision: connected devices, capable AI agents and integrated services. Â
Connected devices, which serve as the customer touchpoint for AI, are one of LGâs greatest assets. Not only are there hundreds of millions of LG smart products already in use worldwide, but with last yearâs acquisition of smart home solutions provider Athom, LG now offers seamless connectivity with IoT devices from over 170 global brands.Â
As for AI agents, LG is set to advance its AI agent, LG FURON, which combines the power of generative AI built on large language models with real-time spatial sensing and insights into customer lifestyle patterns. This innovative AI agent can understand customer situations and contexts in real-time, effortlessly coordinating devices and services to provide a more tailored and responsive user experience, all while protecting personal data.Â
Empowering AI-Based Integrated Services with Microsoft
To support his vision of providing compelling integrated services, CEO Cho announced a strategic partnership with Microsoft. The plan is to lead innovation by combining LGâs products and customer insights from various spaces, such as the home, mobility and commercial areas, with Microsoftâs AI technology to implement empathetic AI integrated services. Â
Judson Althoff, executive vice president and chief commercial officer at Microsoft, shared, âAt Microsoft, we believe AI will fundamentally change the way we live and work, and we could not be more excited to partner with LG Electronics â the pioneers of smart, connected spaces â to integrate AI into lifeâs everyday experiences.â Â
The two companies are working on enhancing AI agents for various spaces, including homes, vehicles, hotels and offices. LG has been applying Microsoftâs voice recognition and speech synthesis technologies to its Self-Driving AI Home Hub, enabling it to understand diverse accents, pronunciations and colloquial expressions. Plans also include developing AI agents that not only understand and interact with customers but also predict their needs and preferences.Â
Althoff also announced further Microsoft collaboration with LG in the rapidly growing field of AI data centers. With LGâs thermal management systems and advanced chiller technologies optimized for AI data centers, the partnership aims to enhance energy efficiency in these critical backbones of AI infrastructure. Together, the companies plan to create next-generation data centers that are more efficient and sustainable.Â
Bringing AI Vision to Life
Illustrating Choâs Affectionate Intelligence vision, LG captivated the audience with a short play about a familyâs day from morning to night. Departing from the traditional product presentation speech format, this vivid portrayal demonstrated how LGâs AI innovations unveiled at CES 2025 and driven by the vision of âBetter Life for All,â seamlessly enhance everyday life across various spaces.Â
In the morning scene, LGâs AI agent, FURON, highlights its personalized capabilities: âI noticed some coughing last night, so I adjusted the room temperature for your comfort.â Beyond environmental adjustments, FURON demonstrates thoughtful assistance, suggesting, âYou donât have any plans this afternoon â why not accompany your mother to her scheduled health check-up?âÂ
The morning commute further highlights the convenience of AI integration. In the car, LGâs AI-powered in-cabin sensing solution detects when the driver forgets their coffee tumbler, asking, âWould you like to stop by a cafĂ© two minutes away for coffee?â It also monitors biometric signals, responding to an elevated heart rate before an afternoon meeting by playing soothing music to help the driver relax. The system also proactively suggests rerouting to avoid accidents and recommends holding a video conference inside the vehicle if traffic delays risk causing the driver to miss an important meeting. Upon arriving at the office, the AI adds a personal touch, such as displaying previously recorded family vacation footage on the carâs internal and external cameras.Â
After work, the living room TV equipped with AI technology enhances the home entertainment experience. It analyzes the viewing environment, patterns and history to recommend tailored content. If the customer mentions difficulty hearing dialogue in a video, the AI adjusts the audio, enhancing voice clarity by isolating it from background noise and making it sound as though itâs coming naturally from the center of the TV screen.Â
Seamless and Holistic Customer Experiences Anytime, Anywhere, Seen or UnseenÂ
Concluding his keynote address, CEO Cho emphasized AIâs role in driving transformative change across both B2C (business-to-consumer) and B2B (business-to-business) sectors.Â
He highlighted innovative initiatives like the LG Smart Cottage, a compact modular home that integrates AI-powered appliances, HVAC systems and other advanced technologies to redefine residential living. Similarly, LG envisions the automobile as a âpersonalized digital cave,â featuring software-defined vehicle solutions and AI technologies that understand and adapt to both the internal and external vehicle environment, delivering groundbreaking mobility experiences.Â
In smart factory solutions, LG leverages over 60 years of world-class manufacturing expertise, offering next-generation manufacturing systems powered by AI and robotics. Additionally, LGâs AI-based thermal management systems and advanced chiller technologies are optimizing energy efficiency in AI data centers worldwide.Â
âOur ultimate goal is simple yet profound: to leverage AI as a means to create holistic customer value, in which ever space you are you are,â said CEO Cho. âIrrespective of how AI transforms our lives, one thing will never change: our promise of Lifeâs Good. With this unwavering commitment, we will continue to strive for industry-leading experiences for our customers â seen or unseen â to everyone, everywhere, every time.â
Â
# # #Â
Company Redefines Premium Gaming Monitors With the UltraGear GX9 Series,
Offering Unmatched Immersion, Flexibility and Smart Features
SEOUL, Dec. 30, 2024 â LG Electronics (LG) is reinforcing its leadership in premium OLED gaming monitors with the LG UltraGear GX9 series, set to be unveiled at CES 2025 this January. The new lineup includes the 45GX990A â winner of three CES 2025 Innovation Awards, including the prestigious âBest of Innovationâ â and an all-in-one smart gaming monitor powered by LG webOS. These accolades underscore LGâs commitment to delivering advanced, high-quality gaming solutions. With the GX9 series, LG continues to demonstrate its leadership in cutting-edge technology and gaming monitor innovation.
To ensure maximum gaming immersion, all UltraGear GX9 series models feature curved display panels employing LGâs advanced WOLED technology. These screens offer high brightness, true blacks, stunning colors and optimized curvature; a combination that brings games to life and draws users deeper into the exhilarating action of their favorite titles. Certified for low blue light emissions, the GX9 series provides a more comfortable experience, reducing eye strain during extended gaming sessions. In addition, LGâs Anti-Glare & Low Reflection (AGLR) coating minimizes screen reflections and glare, making it easier for gamers to see everything thatâs happening on screen, even in brighter rooms.
The 45GX990A and 45GX950A are 45-inch, 21:9 gaming monitors featuring ultra-high 5K2K resolution (5,120 x 2,160) â a first for OLED monitors.* Their 21:9 aspect ratio offers a more immersive gaming experience than standard 16:9 displays, while maintaining better content compatibility than 32:9 monitors. With generous screen real estate, these monitors are a great choice not only for gaming but for various different uses.
Both products feature LGâs second-generation Dual-Mode, offering customizable aspect ratios (21:9 or 16:9) and picture sizes (39-, 34- or 27-inches) with one-touch switching between preset screen-resolution and refresh-rate combos. With eight configurations, users can personalize their gaming setups to suit their preferences or adapt to different game genres, including FPS, RPG, MOBA and racing simulators.
The Worldâs First Bendable 5K2K Gaming Monitor with Dual-Mode
The LG UltraGear OLED Bendable Gaming Monitor (model 45GX990A) is the worldâs first 5K2K-resolution bendable OLED display. The 45-inch monitor can smoothly transition from completely flat to a 900R curvature within seconds, offering users incredible flexibility and more control over their gaming experience. Its upgraded Dual-Mode feature allows users to switch effortlessly between resolution and refresh rate presets, and customize the aspect ratio and picture size. With an ultra-fast 0.03ms (GtG) response time, the 45GX990A ensures smooth gameplay and heightened immersion.
The Worldâs First 45-Inch 5K2K OLED Gaming Monitor with 800R Curvature and DisplayPort 2.1
Another standout model from the new GX9 lineup is the LG UltraGear OLED Gaming Monitor (model 45GX950A). With its curved (800R), 21:9 format 5K2K-resolution self-lit 45-inch panel, this display delivers sharp, lifelike images with the stunning colors and exceptional contrast LG OLED products are known for. Its 4-side Virtually Borderless design and slim bezels help boost usersâ sense of immersion while adding a sleek aesthetic to any setup. Boasting 125 pixels per-inch (PPI) and an RGWB subpixel layout, the monitor improves the readability of in-game text and makes productivity tasks, such as editing documents or website content, that much easier.
Like its bendable sibling, the 45GX950A features Dual-Mode functionality with eight customizable configurations and supports DisplayPort 2.1, HDMI 2.1 and USB-C with 90W power delivery. This ensures seamless compatibility with the latest graphics cards and features such as variable refresh rate (VRR) while enabling convenient device charging. Certified by NVIDIA G-SYNCÂź and AMD FreeSync Premium Pro, the monitor has reduced screen tearing for a smoother, more responsive gaming experience.
Versatile Smart Gaming Monitor for Seamless Streaming and Immersive Gaming
The brand-new LG UltraGear 39GX90SA is designed to deliver stellar gaming and content-streaming experiences. Powered by webOS, it functions as a home entertainment hub, enabling users to access all their go-to streaming services without a PC or set-top box. Itâs 39-inch, 21:9 aspect ratio curved (800R) OLED display produces brilliant, nuanced colors and deep, dark blacks, making it perfect for AAA games and HDR movies and series. Equipped with USB Type-C ports, it offers convenient connectivity, and incorporates LGâs ergonomic and space-saving L-shaped stand for a clutter-free desk setup.
âThe UltraGear GX9 series sets a new standard for OLED gaming monitors, combining groundbreaking display technology with smart features that expand and enhance the user experience,â said YS Lee, vice president and head of the IT Business Unit, LG Media Entertainment Solution Company. âFrom the worldâs first 5K2K OLED gaming monitors with second-generation Dual-Mode to smart gaming monitors with built-in webOS, the GX9 lineup pushes the boundaries to deliver maximum value and enjoyment for our customers.â
* As of December 2024.
Only South Korean Company Recognized in Leisure Equipment & Products and
Consumer Electronics Category for 13 Years
SEOUL, Dec. 24, 2024 â LG Electronics (LG) has once again secured its position in the Dow Jones Sustainability World Index (DJSI World) for the thirteenth consecutive year. The DJSI World ranks the top 10 percent of the largest 2,500 global companies based on their economic, environmental, social and governance (ESG) practices, serving as a critical benchmark for investors assessing corporate sustainability.
Notably, LG earned the highest overall score in the Leisure Equipment & Products and Consumer Electronics industry category. Furthermore, it remains the only South Korean company to be included in this category for 13 years running.
Additionally, LG has been included in the DJSI Asia Pacific (top 20 percent of the 600 largest companies in the Asia-Pacific region) and DJSI Korea (top 30 percent of the 200 largest companies in Korea) for 15 and 16 consecutive years, respectively.
LG received high evaluations across various ESG areas, including environmental policy and management, human rights management, human resource management, customer relations, supply chain management and product responsibility management.
Under the ESG management vision of Better Life for All, LG is carrying out various activities with the strategy of Better Life for All, LG is carrying out various activities with the strategy ofâ3Csâ for the planet (carbon neutrality, circularity and clean technology) and â3Dsâ for people (design for all, decent workplace and diversity & inclusion).
To achieve its 3C goals for the planet, LG has set ambitious targets, including reaching carbon neutrality in its product manufacturing process by 2030 and transitioning to 100 percent renewable energy by 2050.
Specifically, LG plans to reduce direct greenhouse gas emissions (Scope 1) and indirect greenhouse gas emissions (Scope 2) in the product production stage by 54.6 percent compared to 2017 levels. This will be accomplished through process improvements, the introduction of energy-saving technologies and the use of renewable energy. Notably, LG was the first company in the home appliance industry to obtain UN carbon credits in 2015.
In addition, LG is focused on reducing the unit greenhouse gas emissions of its seven major product groups (TVs, monitors, refrigerators, washing machines, dryers and  home and system air conditioners) by 20 percent compared to 2020 levels during the product use stage (Scope 3). This commitment involves various activities aimed at improving the energy efficiency of individual products, thereby reducing overall carbon emissions.
As a member of the UN Global Compact and the Responsible Business Alliance, LG complies with international human rights and labor standards and is enhancing its human rights management processes to respond to strengthening global ESG-related legislation.
In the ESG evaluation and rating announcement results published by the Korea Corporate Governance Service this year, LG received an overall A grade for four consecutive years. LG also received an A grade for five consecutive years in the ESG evaluation conducted by the global ESG evaluation agency Morgan Stanley Capital International, gaining recognition for its ESG management performance from credible domestic and international institutions.
