How to accept a WiFi connection from a Linux PC desktop using the remote
By akhil7j
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Guest
Things that I've tried:
factory resetting the tv leaving the tv unplugged to delete cache using google's DNS on the TV using a wired connection Having said so, I am so lost that I would be happy to try anything again.
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
makem
I have a LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
