Jamie80 Posted June 18, 2024 Posted June 18, 2024 Blue tint on my lg smart tv is there anyway to remove or is it knackered? Quote
0 davexnet Posted June 18, 2024 Posted June 18, 2024 My 2017 TV (uj6500 series) has also started doing this, last few months. On mine it's not uniform, the blue is strongest in the lower left corner. It's almost always due to the LED backlights starting to burn out and the fix is to replace them. If the TV is OK otherwise, it could be worthwhile to repair it. I was quoted $150 US at a small TV repair place to do the job. Quote
Jamie80
