Preware BlacklistOn this third birthday of WebOS Internals' homebrew app Preware, we found it fitting that we give you a Preware-related tip today. Preware is a amazing app that will allow you to search for and install patches, apps, themes and more, and when combined with
you can access the official webOS App Catalog to expand it even further. Even though the app catalog may only be a fraction the size of its competitors, there is still a lot of junk in there that will diminish your browsing experience. Luckily, Preware has a "blacklist" functionality that will prevent those packages from showing up that can be set based on the title, maintainer (developer), package id, app description or category of the package.
To add or edit your blacklist:
  • Open up Preware
  • from the top-left to view the Application dropdown menu and select "Preferences"
  • Scroll to the bottom of the preferences screen to the BLACKLIST section and tap the "+ Add" row to add a new entry
  • On the Add Blacklist screen, there are 2 fields that you need to fill out:
    • "FIELD" determines how what to "search in" to indentify the blacklisted packages
    • "SEARCH FOR" determines the value that you want to search for.
    • For example, to remove any app by "Applible LLC", you can choose Field = Maintainer and Search For = "Appible", or you choose to search "Package Id" for "com.appible"
  • When done, tap the green "Save" button.
  • Back on the preferences screen, on a webOS phones or scroll back to the top of the screen on the TouchPad and tap the back arrow on the top-left of the screen
  • Go back to the main Preware homepage and you should get a pop-up asking you to reload the package list. Choose "Do It Now" to reload the feeds
From here on out, any package that meets the blacklist criteria above will no longer show anywhere in Preware. If you ever need to edit or delete the blacklist, go back to the preferences screen and either tap on the entry to edit it, or it from the screen and confirm the deletion. Be sure to always refresh the feeds any time you make a change to the blacklist
a2t.imgjhEuKvwHBPc
    • By Cody94549
    • By toopie28
      Hi can someone help please.
      Not sure what else to try.
      Thanks!
    • By Batman
      I have a LG 43QNED756RA AEK Smart TV
      If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
      So I cannot Move or Edit Program Numbers or Delete
      Any help and comments would be appreciated
    • By pattox
      It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose  the + add item.  If you want to add a "shortcut" to an item that is not on the list then how can that be done.  Is it possible to edit the list presented?
      Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings,  there nothing on the list of options presented to allow this.
    • By kerbe
      I have six Sonos smart speakers in my home and WebOS recognizes them all as Media Servers, making it necessary to scroll to find the ACTUAL Media Server. Is is possible to set WebOS to NOT recognize the Sonos speakers as Media Servers?
