LG SIMPLINK keeps turning back on since webOS 23 update. Auto Power Sync missing.
By mean2
By OliverRC
By Ajothen
By Roy Brown
By Batman
Flavio_S
These functions are Auto Power Sync and Auto Device Detection.
