PreCentral: preNotes: Photo FunSend Google Voice message to ANY contact with SynerGV 2
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By Calvinder
Any suggestions
By Cody LUEN
Hi!
Version: 23.20.36
By SMKoch
I've had an LG OLED65C9PUA for years and have never had this problem until very recently.
Now every time I try to use the voice command to enter a search sequence, the "SPEAK NOW" activates and shuts off within half a second. It doesn't matter how I activate the voice command function or what app I'm using that has the function built in. Such as YouTube or even the Web Browser or whether I activate the voice search with the onscreen microphone icon or the microphone key on the remote. All voice command attempts shut down within half a second. There isn't even time enough for anything said to be recognized or even "not recognized".
Fresh batteries have no effect on the problem. Turning the TV off and back on has no effect on the problem. Removing and replacing the batteries has no effect on the problem. Reregistering the remote to the TV via the extended holding of the GUIDE button has no effect.
How do I restore the voice command function for the remote?
By 152bobby
I have been trying to get my Google Home and Nest Audio Speakers to turn my LG OLED65C24LA TV on and off. I have linked ThinQ to Google Home but it still wouldn't work. So plan B was to get a Chromecast to do this one simple voice activated request....I have no intentions of using Chromecast for anything else!
So this actually does work, however, when asking it to turn the TV on, it defaults to the home page of Chromecast TV, I want it to just open to my normal TV system, which is Sky Q. Ideally, I would like to disconnect the Chromecast and just get Google Home and ThinQ to do this !!
I have checked every setting and trawled the internet for a solution. I've posted on the AV Forum in the UK and the Google Forum and I'm waiting on a call back from LG Support UK.
I expected this to be a VERY simple task !!
Can anyone help with this ?
