PreCentral: Palm Profile backup failure class-action lawsuit finally paying out, three years later
By fmas2
Hi everyone,
I´ve installed Kodi on LG WebOS. I need to delete some backups that by default are stored in the WebOS root system. I guess it can be done through WebOS Dev Manager but I´ll appreciate any help giving me the path to achieve such backup folder.
Many thanks in advance
By Darshan Giri
I was unable to install the remote control app(on TV) after bundling with Sandstorm webdriver code. Getting below error. ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
By Glen
Appears that my main audio amp has failed, no audio from TV speakers.
The pre-amp is okay since I plugged in sound bars, wireless headsets, and optical connection all ok.
The repair would cost around $300 so I decided it was cheaper to buy a soundbar.
Anyone else experience this problem, ie no sound from the TV speaker?
By philotas
I followed these steps to prepare my LG TV and it all worked fine:
However I cannot push IPK to tv or just list stuff:
I am getting this error when calling:
ares-device-info --device tv2 outputs:
ares-device-info ERR! [syscall failure]: read ENOTCONN Any ideas?
I can ping the TV just fine and getting the key from the TV also worked but connection fail...
I am using macOS 12.16 and the TV is using webOS 4.9...
I also tried different node versions (v8.17.0 and v17.3.0)
Any ideas?
By Reggie Thayil
Recently my LG C1 has been pausing on its own and going back to the profile selection screen while using native apps. This issue occurs while using Netflix, Disney+, Paramount+, etc. I tried using my Firestick and it kept pausing my program. I tried a hard reset and that fixed the problem for 2 days before it started again with Disney+.
I need a fix for this issue ASAP.
