PreCentral: Open webOS on Ubuntu Linux desktop build instructions released
http://forums.webosnation.com/webos-open-source-general-discussion/318203-open-w
Revealed today on the Open webOS GitHub was the next step forward for
: build instructions to install the operating system on an Ubuntu Linux . The instructions, , go over the steps you'l need to take to download, build, install, and run the open source version of webOS, and the first prerequisite you're going to have to overcome is having an Ubuntu Linux machine. If we had to guess, that's not something the vast majority of you have or have access to.
But if you do have Ubuntu installed on your computer, then all you need is a good internet connection for 500MB worth of downloads and 4GB of free space on your hard drive to get started, plus the patience to follow along in command prompt and wait for the build process to do its thing.
And we know the next question you're ready to ask: no, there are not instructions to install this build of Open webOS on a TouchPad, Pre, or any other mobile device. Or your Mac or PC. We're not apologizing for HP here, but right now. Ubuntu Linux is better than nothing, we suppose, but for an operating system that was built around and for touch interfaces, we're not sure how well that's going to work.
We're getting set up to install Open webOS ourselves (Derek doesn't have Ubuntu installed either, so don't feel bad), and will update you once we've got things rolling.
a2t.imgEfRIAXx3V5g
