By
atcronin
Brendank
I had an issue with powering on the tv in which pressing the lg power button on the first ocassion did not turn on my Oled C1 77 inch Tv.
LG replaced the powerboard, however since the replacement I have an issue with intermittent audio dropouts via earc.
EARC has functioned previously on my Tv when connected to an Anthem 710 receiver and for a few months now on an Anthem AVM 70.
The set up has remained the same in terms of audio settings, passthough, match screen and sound set to bypass and I have tried multiple cables, switching the tv off, resetting earc, but I still have the issue.
It is very odd that after a replacement power board I have this issue. It almost seems like a comparability issue between the new board and the existing components or something else is wrong with the TV.
Any ideas?
