PreCentral: TouchPad Go raffle winners announced
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
SANTA CLARA, Calif., October 29, 2024 — Showcasing cutting-edge technological solutions,
link hidden, please login to view, the North America Innovation Center of LG Electronics, announced the winners of the 2024 Startup Pitch Competition, co-sponsored by LG Chem. This year’s event, held during LG NOVA’s annual in San Francisco, featured standout startups focused on Life Sciences, Open Innovation, HealthTech, AI, Smart Life and CleanTech, with three companies recognized for their potential to drive impactful change. Ten startups competed for cash prizes and recognition in front of a panel of industry experts, LG executives and investors. The 2024 winners are:
First Place: . – mDETECT has developed highly-sensitive cancer blood tests using DNA sequencing, offering a universal approach to monitoring therapy response and detecting cancer progression. The company received the top prize of $15,000. Second Place: – Glidance is revolutionizing independent mobility for people who are blind or have low vision with Glide, the first AI-powered intelligent guide, which enhances confidence, safety, and autonomy. Glidance was awarded $10,000. Innovation for Impact: – Oncoustics is transforming low-cost point-of-care ultrasound devices into powerful diagnostic tools for early detection and monitoring of liver diseases using AI. Oncoustics received $10,000 for its selection as Innovation for Impact company. This award category was sponsored by LG Chem. In addition to cash prizes, participants will have the chance to explore further collaboration through LG NOVA’s , which seeks to support innovative startups through potential collaborations, partnership programs, marketing opportunities and other resources.
“We’re excited to recognize startups that are truly pushing the boundary of what’s possible, developing technologies that have the potential to make an impact on people’s lives,” said Dr. Sokwoo Rhee, corporate executive vice president for innovation at LG Electronics and head of LG NOVA. “These companies are leading the way in critical fields like healthcare, cleantech, AI and life sciences and we look forward to exploring opportunities with them as they continue to advance their innovations. Together, we can shape a brighter tomorrow by driving meaningful change through collaboration.”
The fourth annual LG NOVA InnoFest brought together industry leaders, investors and startups to explore emerging technologies in a collaborative environment. This year’s theme, “Lighting the Halo for Innovation,” emphasized the importance of co-creation in driving meaningful progress. The festival featured over 70 speakers, covering topics ranging from building successful ventures and the future of AI to innovative digital care models, energy management and more.
Winners Showcase Family-Friendly Gaming Innovations and
Address the Growing Interest in AI Technologies at LG webOS Summit
SEOUL, Oct. 1, 2024 — LG Electronics (LG) announced the winners of its webOS TV platform hackathon, which took place at the LG webOS Summit last week. The event was geared toward AI-based solutions and gaming services, and sought ideas to enhance the gaming category on the Smart TV.
Developers from around the world applied for the opportunity to present their ideas for apps or services to be used on webOS-based LG Smart TVs in millions of homes, with the goal of diversifying and improving the gaming experience on the LG TVs powered by webOS.
Over three hundred entries were submitted from more than 50 countries. Finalists were invited to present their ideas onstage to a panel of LG executives and over 300 market-leading companies. The top three winners received a meaningful opportunity to engage with the LG team to develop their ideas and resources for business implementation on webOS. They will continue to work with the LG team to prepare the family-friendly gaming solutions for LG TVs by June 2025. Cash prizes were awarded to the top three winners of the hackathon, with the Grand Prize of USD 100,000 for first place, USD 80,000 for second place and USD 50,000 for third place.
Grand Prize Winner: The Quest of Sunflower by Couchplay
An epic adventure game based on an AI-generated story, featuring stunning graphics, immersive audio and responsive game play suitable for the whole family.
Second place: Signs of Magic by Lukas Klingsbo
Set in a magical world, this game follows the wizard Elowen as she battles invading creatures known as Astromentals. It integrates LG Magic Remote sensors to create an immersive experience that brings the action to life.
Third place: Thormdeil: Into the Unknown by TV Games
The first single-player RPG developed exclusively for a Smart TV platform, featuring seasonally AI-generated content. Players navigate dark dungeons, face survival challenges and uncover hidden truths.
“The amount of participation and entries we received this year is proof of the growing interest in the AI and gaming categories,” said Chris Jo, senior vice president of platform business at LG Home Entertainment Company. “We’re no longer simply watching television. The developer ecosystem’s role in improving the lives of millions of consumers in their homes is exponential, and LG plans to hold this event annually to foster webOS app developer ecosystem.”
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
Award’s Final Four Teams Joined by Renowned ESG Scholars and Company’s
Executives at LIFE’S GOOD AWARD Conference in South Korea
SEOUL, Jan. 17, 2023 — LG Electronics (LG) has announced the final winner of its LIFE’S GOOD AWARD, supporting global innovators taking on challenges to help create a Better Life for All. The Grand Prix was awarded to Dot Inc. from South Korea.
The jury ranked the final four teams after each of the teams pitched their innovative solutions in the award’s final round, held during the LIFE’S GOOD AWARD Conference at LG Sciencepark in Seoul, Korea, on January 16. LG’s own executives leading the company’s ESG management, CSO Lee Sam-soo and CTO Dr. Kim Byoung-hoon, were present as well.
The award embodies LG’s ESG vision of a Better Life for All, aiming to foster a brighter future for the planet and people. The company aimed to solicit ideas for environmental sustainability and accessibility, two key focuses of its long-term ESG initiative, the Better Life Plan 2030. The ingenious solutions presented by the four winners illustrate the power and potential of tech-for-good to spread positive impact on the world.
The winning teams are: Dot Inc. of South Korea (Grand Prix/USD 700,000 in prize money); SOLUTUM of Israel (Gold/USD 200,000); Day1Lab of South Korea (Silver/USD 100,000); and NONA Technologies of the United States (Bronze/USD 50,000).
LIFE’S GOOD AWARD Winning Solutions
Dot Inc.: developed an assistive information display device for the visually impaired composed of 2,400 braille pins – or ‘dots’ – which move up and down. The novel device converts images, maps and other diverse digital information from connected devices such as computers and mobile phones into a display for visually impaired users to comprehend. SOLUTUM: developed a novel plastic material that dissolves in water at ambient temperature and then biodegrades leaving no microplastic or toxin residue. Day1Lab: created an organic polymer plastic which completely biodegrades in freshwater after about two weeks, and in the earth after about two months. NONA Technologies: developed a desalination solution leveraging Ion Concentration Polarization (ICP) to remove viruses, bacteria, salt and debris from water. Along with the final four teams, the LIFE’S GOOD AWARD Conference was graced by the esteemed members of the award’s jury, the LG’s Life’s Good Committee, consisting of the company’s executives and respected scholars in the area of responsible business management; Alex Edmans, a professor at London Business School, Christopher Marquis, a professor at Cambridge Judge Business School and Hyun S. Shin, a professor at Hanyang Business School and a director of the Collective Impact Center at Hanyang University.
The conference saw various attendees – including members of the public and local university students as well as LG employees and partners – and was livestreamed so that audiences from all around the globe could tune into the proceedings. During the morning, all four teams gave a final presentation and participated in a Q&A session, while the jury provided feedback based on the impact, innovation and sustainability of each solution. The afternoon featured an awards ceremony honoring the four teams and announcing their final placings, as well as special lectures delivered by Professor Edmans, Professor Marquis and Professor Shin.
“We will continue to pursue solutions assisting the visually impaired, and thanks to LG’s support, we will be able to achieve this at a greater scale and in less time than we otherwise would have,” said Ahrum Choi of Dot Inc., Grand Prix winner of the LIFE’S GOOD AWARD. “We are so grateful for this experience and are looking forward to collaborating with LG in the future, a company that really shares our desire to make the world a better place.”
“We will continue to collaborate with like-minded innovators as we forge ahead on a shared journey to create a sustainable future for all, embracing the company’s Life’s Good vision,” said Lee Sam-soo, Chief Strategy Officer at LG Electronics.
Meanwhile, LG will carry out ESG efforts spearheaded by the Better Life Plan 2030 and continue to share the initiative with internal employees and external stakeholders in order to bolster the company’s sustainable business practices.
For all the latest on LG’s ongoing efforts to realize a Better Life for All, stay tuned to
