HP discontinues webOS live chat support
It's been
since . There's been for that HP intends to produce new webOS hardware, and they've gotten to the point where they're . So while it's disappointing, it's not surprising to see that HP has shut down customer support live chat for webOS. The service has proven helpful to a good many of our readers (your dear editor even used it once or twice), so we're sad to see it go.
Now anybody visiting the is met with a message that "this service has been discontinued" and recommending other ways to get help, including the on-device help app, HP's support forums, and elsewhere on the webOS support website. For visitors to the chat page, the support forums would probably be the best option for getting close to the level of in-depth assistance you could get through chat, but if we're being perfectly honest . . We might be biased, but our community is just more awesome at this.
a2t.imgw51nSEetOHg
    • By tarakdave
    • By Nick Payne
    • By Charlie F
      Charlie
    • By Bella Lee
    • Solution For That Pollution
    • By Alex
      Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
      LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
      Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
      Source:
