PreCentral: Enhanced Contacts VCard Export patch fixes webOS contact export
This tip is currently only for devices running webOS 2.2.4
Export contactsYou always want to make sure that you have a backup of your critical data that you keep on your smartphone, and your contact list should be towards the top of your priority list when to comes to ensuring you have recent backup. If you use cloud-based synergy accounts for your contacts like Google Contacts, Facebook or Yahoo, you are probably less worried about having a backup since you can always go back to the source data and pull it down again. But if you use the Palm Profile or a different "local" account for your contact data, the only way to access your data is on the phone itself, and if the phone is lost or your backup gets corrupted, you run the risk of forever losing that data.  Luckily, there is a rather simple method to perform an
. This is useful to not only create a backup of your data, but also would allow you to easily migrate your data to a different service like Google Contacts.
Unfortunately, it appears that since webOS 2.1 this export does not include the "Spouse" or "Children" fields in your contacts, and the URL field is not saved with the right field type. This is obviously not ideal as you will no longer have a complete backup, nor will you be able to migrate all of your data to a different service. In order to combat this, webOS Nation forum member gizmo21 created the "Enhanced Contacts VCard Export" (available in preware) that will fix these issues when you perform an export of either a or
Currently, this patch is only available for webOS 2.2.4. If you would like to help gizmo1 test this patch for webOS 2.1 or 3.0.5, reply in the to let him know.
a2t.imgPb5LoiuiN1I
