App Review: Neo
Last month developer Bryan Leasot was kind enough to give us a very early
of his up and coming Twitter app Neo. At the time the app was in an extremely early beta stage and was a little rough around the edges but showed a great deal of promise. Despite the app’s then rough edges, we really liked the extreme customization options found in Neo. To our knowledge, there is simply no Twitter client that allows such a deep level of customization. In the end we walked away impressed and looking forward to an official release of Neo. So here we are a month later putting the official version of Neo through its paces. Are we still as impressed as we were last month?
Once you are signed in to Twitter, you immediately notice just how different the appearance of Neo is when compared to other Twitter apps on the TouchPad. Instead of the expected rounded boxes, gray menus, and webOS icons, you're greeted by a more angular look that is far from typical for a webOS app. While a squared-off interface is all fine and dandy, what makes Neo really stand out is this interface is customizable (although we must say we really dig the stock theme).
Customizing Neo can be a rather time-consuming affair if you're as picky as we can be, but considering the number of things you can customize that's to be expected. Thankfully this is all accomplished via sliding bars to adjust the various colors, sizes, and other settings. The end result can be an app that is highly personalized. You can save your custom themes for later use and can even email your custom themes to share with your like-aesthetic friends (or whip up something awful and send them that instead).
a2t.imglrjphy9XId4
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
