Repeated issue with Freeview disappearing overnight
By nigelh
I have an LG43UN71006LB TV. I don't have an option to download the Freeview app. When I search for it in Content it isn't found. However I was told that the app should be available on this model. Would appreciate if anyone could confirm I this is the case and if so why it isn't available to download.
By RJ Fischer
By Regis Wheeler
By JasonB
