IPTV Applications Subtitle Problem?
Are you sure the channel you are watching provides subtitles?
IPTV cannot just magic them up for you
I have IPTV smarters installed on my LG TV
I do get subtitles on series, but only arabic
Maybe a function of my location
Nothing on live channels
If you're having trouble with subtitles on IPTV applications, it could be because the channel or content you're watching doesn't offer them. Subtitles depend on the source, so not all shows or live channels may provide them. You can try using IPTV Smarters, which some users have found supports subtitles for certain content like series, though it may vary depending on your location. Also, check the app settings to see if there's an option to enable subtitles.
    • By Venkata
      Hello Team,
    • By Adnan Ali
      Hi, I’m planning to develop an IPTV app for webOS and would like to know the best technology stack to use. Should I go with a hosted URL or develop it using native code?
    • By PVD
    • By hollean
    • By AJO
