    • By SSM
      TV MODEL: LG 43UJ635V
      DATE OF PURCHASE: 21/11/2017 (4 days ago from post date)
      RETAILER: ARGOS UK
      WEBOS VERSION: Can't check right now but after I got the TV I updated straightaway to 4.7.XX
      INTERNET SPEED: 75Mbps Down / 20 Mbps Up
      Hello, I've recently purchased the LG 43UJ635V, as soon as I turned it on and went through first time setup I noticed there was a bit of lag in the animation when I pressed the home button (the moment all the tiles 'bounce' up), however whenever I get off that menu the animation is smooth and everything else is fine. This always happens, I have tried resetting the TV to its initial state and nothing has changed. - Just wondering if anyone else has had that issue?
      At one point I changed some of the image quality settings and the whole OS just started lagging making it difficult to navigate so I had to reset the TV  for the 3rd time.
      Also, occasionally when using apps such as YouTube or the web browser the app will restart with a notification in the top right saying the restart was to clear some memory. Although this isn't too common, I've seen other posts from months ago about people having a similar issue but the apps constantly restart.
      I close all recent apps which doesn't change the lag on the home menu but I haven't seen the restart notification in a while which seems like a good sign but I also have been using the internet browser much.
      With all the negative experiences I've read about, (related to the memory and general lag) I'm not sure whether I should return the TV or not.
      Thank you.
      TL;DR: Lag when pressing the home button and all icons appear but no lag when returning to the current app, occasional app restarts due to a low amount of memory.
