PreCentral: Monday Brief: iPad 4, iPad mini, Nexus 4, Lumia 920 and more!
By Lesbo
Key Specifications:
By Dann
Bonjour à tous
Je viens d'acquérir une tv LG oled 48c3 que je veux brancher sur une barre de sons Sennheiser ambeo mini.
Côté Sennheiser c'est assez simple, mais de celui de lg c'est plus compliqué, vu toutes les possibilités de réglages .
Sur la tv LG une sortie eHDMI que je branche sur entré eHDMI de la barre de sons.
Le son ne sort pas sur celle-ci qui est en marche.
Je pense qu'il y-a un réglage que je ne sais pas faire, quelqu'un peut-il m'aider?
Bringing Superb Mini LED Picture Quality to the Healthcare Sector, Company’s Latest
Surgical Display Delivers Outstanding Image Accuracy, Performance and Convenience
SEOUL, Nov. 15, 2022 — LG Electronics (LG) is unveiling its first 27-inch, 4K surgical monitor with Mini LED technology (model 27HQ710S) at MEDICA 2022, the international tradeshow for the medical sector taking place in Düsseldorf, Germany, from November 14-17.
LG 4K Mini LED surgical monitor boasts exceptional picture quality courtesy of the company’s Mini LED technology, which provides clear, precise images. The product’s 27-inch, 4K resolution (3,840 x 2,160) screen leverages thousands of tiny LED diodes to provide a peak brightness of 2,000cd/m² and a 1,000:1 contrast ratio. With an impressive 1,500 local dimming zones, the surgical monitor displays vibrant, high quality color images with consistent brightness across the entire screen.
In addition to contributing to excellent image reproduction, LG’s new surgical monitor’s bright, high quality display is suitable for use in hospital operating rooms and surgical centers. The surgical monitor also covers 20 percent more of the sRGB color gamut than its predecessor (model 27HJ710S). The combination of these attributes, along with a compact and easy to clean design, makes LG’s surgical monitor a valuable addition to the surgical suite.
Furthermore, the design of the new surgical monitor delivers the durability and reliability optimized for the surgical environment. Thanks to the use of Optical Bonding Glass, the 27HQ710S reduces distracting reflections from theater lighting, while the product protects its front and rear (IP45- and IP32-rated, respectively) against foreign material and splashes.
“The market for medical monitors that can deliver bright, high quality color images in true 4K resolution is growing in size, and this is reflected in the products being showcased at this year’s MEDICA,” said Silas Choi, vice president and head of the B2B solution business division at LG Business Solutions Company. “The 27HQ710S is the result of LG’s efforts to bring its superior LED technology to the medical sector. We believe that this new model will be a valuable addition to the surgical suite.”
Visitors to LG’s exhibition booth (Hall 10, Stand D40) at MEDICA 2022 can explore the full range of LG medical displays, including the new 4K Mini LED surgical monitor.
Specifications:
LG Surgical Monitor (27HQ710S)
Panel Inch (Aspect Ratio) 27-inch (16:9) Resolution 4K (3,840 x 2,160) Backlight Technology Mini LED Surface Treatment Protection Glass (1.3t, Anti-reflection, Anti-fingerprint) Color Gamut (Typ.) DCI-P3 110.9% (CIE1976, Area), DCI-P3 98% (CIE1976, Coverage), sRGB 139% (Area), sRGB 100% (Coverage)
Viewing Angles (CR≥10) 178° (Right / Left), 178° (Up / Down)
Brightness (Typ.) 800cd/m2 Contrast Ratio (Typ.) 1000: 1 Response Time 5ms (GTG (Gray-to-Gray)) Feature DICOM Compliant Yes HW Calibration Yes HDR HDR 10, HDR Effect Super Resolution+ Yes Video Signals
Input Terminals HDMI 2.0 x1, DisplayPort x1, DVI x1, 3G-SDI x1 Output Terminals DisplayPort x1, DVI x1, 3G-SDI x1 Connectivity USB 1 Upstream (ver. 3.0), 1 Downstream (ver. 3.0) Power Input AC: 100-240VAC, 50/60Hz Monitor DC in 19V~24V
Power Consumption (Max.) 120W Power Consumption (DC Off) Less than 0.3W Resistance Rating IP45 (Front), IP32 (Excluding Front), IK06 User Convenience Picture-By-Picture: Yes (2PBP / 3PBP / 4PBP) / Picture-In-Picture: Yes Rotation & Mirror Mode, Failover Input Switch, 2 Hot Keys, Flicker Safe
Physical Specifications Weight 8.0kg (18lb) # # #
