PreCentral: CyanogenMod 10 for the TouchPad almost ready for prime time
CM10 for the TouchPad almost ready for prime time
Back in August, TouchPad hacking mastermind James Sullins released a really early build of CyanogenMod10 for those of us daring enough to try something that is far from stable in the
. At the time this early ROM worked but was missing several key elements like sound and hardware acceleration. Despite missing some fairly important things for the typical daily driver, James' early build showed a bunch of promise and oozed the that is a staple point of . However, after the initial release James disappeared, leaving us all craving for some more Jelly Bean action. After several months we were starting to think the project was dead. Then, out of seemingly nowhere, a new build of CM10 hit the interwebs and to our surprise it's amazingly stable, despite being carrying an experimental pre-alpha build label.
So what has changed? First and foremost, CM10 now has sound and hardware acceleration, so Netflix and YouTube lovers will be happy with their video framerates and, well, having audio. This build also has working microphone functionality, which has been a sore spot for CyangenMod 9 TouchPad users due to the proprietary drivers needed for our beloved tablets. During our testing we have found that mic functionality is a bit finnicky, especially when trying to use . It's still pre-alpha, so take that performance with a grain of salt. Outside of that, almost every app we tried from simple Twitter apps to graphically-intensive games all worked without a hitch.
With all this goodness in tow you are probably wondering why this hasn't been released as an alpha or an official nightly. Well, that's because there are several kinks that still need to be ironed out. For example, many people from the various forums following this build have experienced several different battery and charging issues. During our testing of James' newest build from November 8 we experienced fantastic battery life in comparison to what we've experienced with CM9. That said, our TouchPad on this CM10 alpha wouldn't take a charge without turning on USB debugging in Android's developer options. Don't ask us why this managed to fix the issue, but it did. In addition to battery and charging issues, users may also experience the occasional force close of an app and no camera support (no surprise on that one, and not a great loss considering the quality of the TouchPad's lone front-facing camera).
Outside of the above-listed issues we have found this build of CM10 to be pretty darn stable. So much so that we probably won't be moving back to CM9 anytime soon for our Android needs. But that's only because we've already got it installed - like all things experimental (see ), we aren't yet ready to suggest you dive in with CM10 as a daily driver operating system. But if you are the adventerous type, just hit up the source link below for more info. As soon as something more stable is released, be prepared for full walkthrough on how to get your TouchPad up to date with CM10. If you have yet to take the plunge and dual boot your TouchPad with webOS and Android 4.0, be sure to check our our great .
a2t.imggZfNe8Txdq4
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
      Company Announces Integration of Latest Intel Core Ultra Processor in the LG gram
      Lineup at Intel Launch Event, Marking Giant Leap Forward for Personal Computing
      SEOUL, Sep. 4, 2024 — LG Electronics (LG) is excited to announce that its newest LG gram laptop featuring the Intel® Core Ultra processor (Series 2) will be showcased at the Intel Core Ultra Global Launch Event from September 3-8. Renowned for its powerful performance and ultra-lightweight design, the LG gram series now integrates advanced AI capabilities powered by the latest Intel® Core Ultra processor. The LG gram 16 Pro, the first model to feature these new Intel processors, will be unveiled before its release at the end of 2024.
      As the first on-device AI laptop from the LG gram series, it offers up to an impressive 48 neural processing unit (NPU) tera operations per second (TOPS), setting a new standard for AI PCs and providing the exceptional performance required for Copilot experiences.* Powered by the latest Intel® Core Ultra processor, the LG gram 16 Pro is now more efficient thanks to advanced AI functionalities such as productivity assistants, text and image creation and collaboration tools. What’s more, its extended battery life helps users handle tasks without worry.
      The Intel® Core Ultra processor (Series 2) AI processor, which is three times more powerful than its predecessor, enhances a PC’s AI performance dramatically. With up to 48 NPU TOPS and up to 67 GPU TOPS, this next-gen processor offers up to 120 total platform TOPS to unlock new levels of productivity while maximizing user convenience. The new LG gram offers a smoother user experience, since the Intel® Core Ultra processor is optimized for Windows PCs.
      “Together with LG, we are bringing to market the next generation of AI PCs that offer incredible performance, power efficiency and security capabilities for consumers. The LG gram 16 is a great example of an ultra-lightweight AI PC, powered by the all-new Intel® Core Ultra processor, that delivers an outstanding and seamless experience for creators, working professionals and everyday users. We’re thrilled for people to experience the wide-ranging benefits these AI PCs can enable,” said Michelle Johnston Holthaus, Intel executive vice president and general manager, Client Computing Group.
      “Building on LG gram’s renowned ultra-lightweight design and powerful functionality, our newest model integrates Intel’s exceptional AI technology to push the boundaries of on-device AI laptops,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “The enhanced performance and productivity offered by the latest Intel® Core Ultra processor is poised to enrich the LG gram user experience with AI, ushering in a new era of on-device AI laptops.”
      In line with the company’s AI vision of “Affectionate Intelligence,” an approach that seeks to understand customer needs and deliver differentiated experiences that go beyond traditional AI, LG plans to add more AI processor models to its gram lineup following the introduction of the LG gram 16 Pro with Intel® Core Ultra processors (Series 2).
      * Rolling out gradually in preview within the latest update to Windows 11 in select global markets. Timing of availability varies by device and market. Learn more here: aka.ms/WindowsAIFeatures.
    • By C3_User
      I love the Always Ready feature on my LG C3. I've configured it to include the beautiful wallpaper options and it works great with the LG remote.
      However, I use a Chromecast remote to control my TV and my Chromecast together. I've configured the Chromecast power button to control the TV's power. Unfortunately, the Chromecast remote's power button turns the TV off instead of switching it to Always Ready mode.
      LG support agent told me the Chromecast remote is "probably not fully compatible" with the feature.
      Does anyone here have a solution?
      If not, it would be great if someone from LG put this in as a feature request.
      BINGE Korea on LG Channels to Give LG Smart TV Owners in 23 Countries
      Over 40 Channels of Top-Quality Korean Content to Enjoy
      SEOUL, July 11, 2023 — LG Electronics’ (LG) exclusive, free streaming service, LG Channels, is set to present LG Smart TV owners in Australia, Europe and Latin America1 with a vast selection of compelling K-content, which has gained growing popularity worldwide. Spanning multiple genres and offering something for every age and taste, BINGE Korea is the latest collaboration between LG and South Korea-based digital content and platform distribution company, NEW ID, the first in-house venture of the media group NEXT ENTERTAINMENT WORLD (NEW).
      In June 2023, LG launched YTN on LG Channels in Australia, Brazil, Mexico and Europe, bringing live news directly from Korea’s first 24-hour news service to a global audience.
      Building on this, LG is expanding the selection of K-content available on LG Channels with the introduction of BINGE Korea. LG Smart TV users in the applicable markets will have more than 40 channels at their disposal, allowing them to watch Korean news, entertainment and lifestyle shows, K-dramas, K-pop, animation and more – all without a paid subscription. Whatever their preferences or interests, users will find a wealth of great viewing choices on the new home of K-content on LG Channels.
      Popular Korean TV shows like Running Man, the beloved SBS series that offers friendly competition and laughs as 2 teams compete to win missions – often involving well-known Korean landmarks – are available to watch. Coming in July, LG is proud to present a collection of K-dramas that includes historical favorites, such as The Nokdu Flower, and iconic series set in modern-day Korea, such as The Heirs. The latest wave of K-content to arrive on LG Channels will also feature the NEW KMOVIES channel from NEW ID and an exciting lineup of SLL drama titles.
      LG Channels has become a go-to hub for K-pop enthusiasts around the world, enabling them to watch their favorite pop stars perform on the large screens of LG’s Smart TVs. Among the must-see shows users can now tune into is Inkigayo, SBS’s weekly Korean music ranking program which features the hottest K-pop artists of the moment. They can also head to the NEW KPOP channel for a variety of K-Pop TV shows boasting music videos and live performances, as well as reality shows, K-dramas and documentaries.
      Younger viewers will be enthralled and engaged by the delightful collection of Korean children’s programs on LG Channels. From Toony Planet and Kongsuni, to Tobot and Robocar POLI, there are plenty of colorful characters and exciting adventures to captivate the youngest members of the household.
      Many of the 40-plus K-content channels on BINGE Korea provide user-friendly options to enhance the viewing experience for overseas audiences, including content dubbed in English, and programming with subtitles available in English, Spanish, French or Italian.2
      Viewers can access LG Channels by pressing the dedicated button on the Magic Remote or the LG Channels icon on their LG Smart TV’s home screen. This takes them to a full-page menu where they can learn all about the diverse channels on LG’s free, premium service. Every channel is assigned an IP- number which can be easily inputted using the number pad on the remote.
      LG Channels can also be activated via antenna (over-the-air) by selecting the Live TV button on the main screen. This method allows viewers to browse both broadcast TV channels and LG Channels at the same time. BINGE Korea channels can be found starting at IP-800 in Australia, Europe and Latin America.3
      LG Channels is LG’s exclusive free streaming service, offering a wide selection of premium live and on-demand programming, including movies, TV shows, news, sports, children’s programs and more. With an always growing number of channels in 27 markets globally, LG TV owners can easily discover their favorite programs by launching the LG Channels application on their LG TV’s webOS platform (LG Smart TV models 2016-present).
      With its extensive and expanding library of premium K-content, LG Channels continues to take the lead in delivering the best of Korean news, entertainment and culture to viewers worldwide.
      1 Content available in sixteen markets in Europe (Austria, Belgium, Denmark, Finland, France, Germany, Ireland, Italy, Luxembourg, Netherlands, Norway, Portugal, Spain, Sweden, Switzerland, United Kingdom) and six markets in Latin America (Argentina, Brazil, Chile, Colombia, Mexico, Peru).
      2 Subtitle language varies by title and country.
      3 Viewers in Belgium, Denmark, Luxembourg, Netherlands, Norway, Sweden, United Kingdom can launch LG Channels from the app, while viewers in other countries can also launch the channels over-the-air, by selecting Live TV and browsing the channel numbers.
