PreCentral: Choose which email account to reply/send a message from
Choose sending email accountWith webOS synergy you can have up to 16 different email accounts loaded up on your webOS device. If you are viewing an email message or browsing the listing of messages from within a folder of a specific account, when you go to create a new message or reply to an existing one the sending email account will be the one that is currently up on your device. Alternatively, if you create a new message through
or tap on an email address elsewhere in the device, the email will be automatically set to be sent from you . But what if that wasn't the email address you wanted to send them message from?  Well, to send the email from a different account, all you need to do is tap the email address on the "FROM" row on the top of a new email message to change the sending address.
There are two main reasons why you would want to use this functionality.  First, as mentioned above, if you are using Just Type to being a message but don’t want to use your default email account, you can easily change it. Second, if you received an email message to one account, but wanted to reply using a different account, you don't need to jump through any hoops or find any workarounds to move the message between accounts. Just tap reply and then change the "FROM" address.
This tip works on all webOS devices and versions, from the original Pre to the TouchPad.
a2t.img06YgeoE3IBo
    • By Batman
    • By Damian1
      After searching high & low, & also on the difficult to navigate LG website, I can't find which magic remote is compatible for my TV.
      The model.of my LG TV is - 32LQ630B6LA
      Can anybody assist, please?
      Many thanks.
    • By sunnythekid
      Hi, I have recently purchased the 55UT73006LA series TV and wanted to know if any magic remote will work with this TV? If yes, please let me know which one(s), as I don’t really have knowledge on what works with what.
      Thanks!
    • By JaGatorEd
      I purchased MR23GN and while most of the functions seem to work ok, the message of "Remote not supported by this TV" keeps popping up.
    • By coltaz
