I can't connect  my LG ThinQ app to Google Home app.
But my tv, the LG Web OS TV  UM7100PLB ( 2019 ), is in the LG ThinQ app. I even reinstalled it.
Is my TV too old ?
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By JamesH
    • By DavidSr
    • By Fredrik Andersson
    • By akhil7j
