Subtitles via LG ThinQ app
Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
      Company Enhances Smart Home Connectivity With Open API
      SEOUL, Dec. 17, 2024 — LG Electronics (LG) has fully opened the Application Programming Interface (API) of its smart home platform, LG ThinQ, enabling developers to easily create smart spaces with LG appliances.
      Recently, LG launched the LG Smart Solution API Developer website (
      link hidden, please login to view) to officially open up the LG ThinQ API. An API acts as a digital connector that allows different software to exchange functions seamlessly. Developers can utilize the open API to integrate various features from LG AI appliances into their programs or systems, enhancing their services. The LG ThinQ API is divided into two categories: the ThinQ API for individual users and the ThinQ Business API for corporate partners. The ThinQ API allows for remote control of LG devices installed in homes or buildings and facilitates integration with various platforms.
      For individual users, the ThinQ API supports the control and monitoring of AI appliances registered in the LG ThinQ app from various smart home platforms. By utilizing the ThinQ API, anyone can easily create a customized smart home that fits their lifestyle. For example, users of the global smart home platform Home Assistant can now connect and control 26 types of LG AI appliances, including refrigerators and washing machines, within their existing smart home environment. Home Assistant is a community-based open platform with about one million users worldwide who collaboratively develop various smart home functions such as device automation and feature expansion.
      For enterprises, the ThinQ Business API supports partners operating office or residential buildings in integrating and managing various LG products, from appliances to commercial equipment like HVAC and signage, with their existing apps. For instance, large residential buildings can integrate LG appliances with their existing management apps for more convenient use. Residents can reserve the use of LG washers and dryers in common areas through the building management app, or administrators can detect abnormal conditions in the building using LG’s temperature and humidity sensors and quickly respond to issues through alert functions.
      Meanwhile, LG has accelerated the integration of external products and services into the LG ThinQ platform by acquiring the smart home platform company Athom, known for its extensive IoT device connectivity. Athom’s smart home hub Homey currently connects over 50,000 types of appliances and IoT devices, and the Athom app store features around 1,000 apps that connect and control products and services from global brands like Philips and Aqara. LG plans to integrate Athom’s extensive open ecosystem and IoT device connectivity into the AI home hub LG ThinQ On, aiming to realize an AI home where generative AI better understands customers and provides optimal space solutions.
      “With the official launch of ThinQ AI, we aim to deepen engagement with open-source community smart home power users in the open-source community and broaden our collaboration with B2B partners. This initiative will bolster our efforts to create smart home ecosystems powered by LG appliances, enhancing customer experiences across multiple touchpoints,” said Kim Kun-woo, vice president of LG’s Home Appliance Solution Company.
      * The main image is demonstrating potential use of the LG ThinQ API. Actual use may vary.
    • By MURAD
    • By Alex
      Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
      LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
      Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
      Source:
    • By Miguel Gonzalez
      I am lifetime LG CUSTOMER.
      I have a fridge, air conditioned etc. all with THINQ can be accessed remotely (WAN ACCESS)
      Some years ago I purchased 65UM7100PLA but this device is accesible only in LAN/WLAN via  THINQ
      I though this is because old WEBOS version, but I have purchased a new 32LQ63006A with WEBOS22 and I am not able to acces the TV via WAN. It,s the same. THINQ works only in LAN, at home
      I question if there is any way to remotely (WAN) access to my TV,s???
      This can be for security reasons (turn on /off away home etc.
      If  fridge, air conditioned can be accesible by WAN whyy tv not????
      Revolutionizing AI Homes With Affectionate Intelligence for
      Seamless Connectivity, Custom Comfort and Care
      SEOUL, Aug. 29, 2024 — LG Electronics (LG) is unveiling the LG ThinQ ON AI home hub featuring Affectionate Intelligence at IFA 2024 in Berlin, Germany, from September 6-10. This innovative hub provides outstanding connectivity and expandability, positioning itself as the centerpiece of a comprehensive smart home ecosystem, where LG’s appliances and “empathetic” AI work in unison to deliver customized comfort, care and convenience.
      The AI home hub seamlessly connects with a vast array of appliances and Internet of Things (IoT) devices, making it easy for anyone to configure and enjoy a personalized AI-powered home. Powered by LG’s unique Affectionate Intelligence, the ThinQ ON continuously learns from individual usage patterns and broader usage trends to tailor customers’ daily experiences, accelerating the realization of LG’s “Zero Labor Home” vision.
      Compact and lightweight, LG ThinQ ON features a cylindrical form factor and a muted color palette (gray/white) that allows it to blend effortlessly with any space or décor. The device is equipped with an AI speaker that facilitates conversations with LG’s AI voice assistant and lets users listen to their favorite audio content. The ThinQ ON’s advanced capabilities are driven by LG’s high-performance AI chipset, designed with future scalability in mind.
      Generative AI-based Home Solutions Tailored to Each Customer’s Preferences
      The ThinQ ON allows users to control their AI appliances and living spaces with spoken commands or requests delivered in a natural, conversational manner. This creates an experience akin to conversing with friends or family, adding a more human dimension to user-device interactions.
      In addition to comprehending everyday language, LG’s AI home hub can understand the context of conversations and determine user preferences for each connected appliance, IoT device and service; bringing a new level of “care” to the home. What’s more, the ThinQ ON autonomously monitors all elements within the smart home ecosystem, helpfully informing users when a task is completed (e.g., the washer has finished a cycle) or if any issue had been detected.
      On top of this, ThinQ ON makes it possible to check or change nearly all appliance settings using only voice commands and configure convenience-enhancing routines that automate appliance/IoT operations.
      Connectivity, Expandability and Versatility
      LG ThinQ ON is Matter-certified* and supports various network connectivity options, including Wi-Fi and Thread, ensuring hassle-free setup and a seamless smart home experience. Compatible with a wide range of LG innovations and a growing number of appliances and IoT devices from other manufacturers, the ThinQ ON enables users to manage their entire smart home ecosystem from one place, both now and in the future.
      To further enhance the connectivity of the ThinQ ON, LG acquired the smart home platform company Athom in July of this year. Athom’s flagship smart hub, Homey Pro, can connect to over 50,000 devices. The Homey App Store features around 1,000 applications for connecting and controlling products from various global brands. LG plans to maximize the advantages of the ThinQ ON’s open platform by continuously expanding the range of supported brands and devices.
      Enhanced Security and Privacy Protection with LG Shield
      The ThinQ ON utilizes LG Shield, the company’s proprietary security system, to protect customer data at all times – from collection and storage to usage. LG Shield encrypts user data and securely stores it in a separate server. Additionally, data modifications required are made within a secure environment, preventing external parties from tampering with the operational code and ensuring customers’ safety while they enjoy the many benefits of LG’s latest AI-driven innovations.
      “An AI voice assistant and hub that serves as the center of the smart home, ThinQ ON brings us significantly closer to realizing our vision of the Zero Labor Home,” said Lyu Jae-cheol, president of LG Electronics Home Appliance & Air Solution Company. “LG aims to make the ‘AI Home Lifestyle’ accessible to everyone, and will continue to deliver customized comfort, care and convenience through its Affectionate Intelligence solutions.”
      Visitors to IFA 2024 (September 6-10) can see all of LG’s latest AI Home solutions, including ThinQ ON, at the company’s exhibition booth in Hall 18, Messe Berlin.
