How do you measure your productivity? Are there specific metrics you use?
By anna groove
By Will M
By Gene680
It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing? It’s when I’m streaming on Sling.
