PreCentral: Drop a marker pin / create favorite places in Google Maps (homebrew)
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
At the heart of LG appliances lies its powerful Core-Tech, now enhanced with AI capabilities. This technology enables intelligent control of key components, enhancing energy efficiency, ensuring delicate performance and delivering tailored solutions that embody LG’s vision of a Better Life for All.
For instance, LG washing machines feature AI DD, which combines deep learning technology with the company’s 6 Motion Direct Drive technology. This system analyzes fabric types and optimizes washing cycles, utilizing six unique drum motions to provide tailored care for all kinds of fabrics. This not only enhances washing efficiency but also minimizes damage to clothing. However, LG’s commitment to enriching lives extends beyond products. LG offices worldwide actively utilize the company’s laundry solutions to benefit local communities.
In September, Typhoon Yagi ravaged large parts of Southeast Asia including Vietnam. In response, LG Vietnam took action to help the residents of Nam Định and Yên Bái by operating mobile and stationary laundry stations free of charge. This initiative allowed nearly 425 locals to clean approximately 3.5 tons of clothing and blankets.
To handle this significant volume of laundry, LG deployed over 60 employees to operate the washing stations, which were fully equipped with advanced washers and dryers. This ensured that every item was thoroughly cleaned and deodorized after exposure to contaminated floodwater.
This initiative builds on LG’s previous efforts to assist communities in central Vietnam affected by natural disasters in 2020, where free laundry stations across the Quang Binh and Quang Tri provinces cleaned nearly 1,000 kilograms of laundry.
Once this vital campaign concludes, LG Vietnam plans to donate the washing appliances used to educational and medical institutions in Yen Bai and Nam Định, ensuring they continue to serve the community. In addition, the company provided residents in 24 northern provinces with a special warranty from September 12 to October 10, covering repairs for LG appliances and electronics damaged by the typhoon.
In India, LG has embarked on a new business venture with the launch of LG Laundry Crew, a self-laundry service designed for college and university hostels, starting at Galgotias University in Greater Noida this February.
This service delivers the convenience of LG’s washers via the user-friendly “Laundry Crew” application, which facilitates reservations, operations and payments. This first-of-its-kind IoT-enabled laundromat system alleviates one of the biggest challenges of campus life, allowing students to save time for their studies.
To enhance students’ lives, LG India had opened around 100 self-laundry service centers in various college campuses across India and plans to further expand this service to reach 200 self-laundry service centers.
LG is equally committed to enhancing convenience for its commercial business partners. In Thailand, the company has expanded into commercial washing machines with the launch of its first LG Laundry Crew laundromat in February, coinciding with its launch in India. This expansion highlights three key strengths: strong consumer trust in the brand, specialized commercial washing machines and dryers tailored for laundromats and comprehensive after-sales services for store owners.
With Thailand’s flourishing laundromat industry showing significant growth potential, combined with LG’s 35-year market leadership in the washing machine segment, LG Thailand was inspired to introduce the LG Laundry Crew—a pioneering laundromat franchise prototype. As the first official LG-branded laundromat franchise in Thailand, LG stands as the sole provider of commercial washing and drying machines specifically designed for laundromats, enabling entrepreneurs to optimize their investments and reduce operational costs by avoiding oversized equipment.
LG’s established consumer trust and efficient after-sales support system underscore the company’s confidence in the success of this laundromat franchise venture. LG Thailand offers franchise owners an extensive range of benefits, including comprehensive after-sales support featuring complimentary monthly maintenance services for the first two years and bi-annual drum cleaning services to ensure consistent cleanliness and odor-free operation.
More importantly, in response to the recent devastating floods in northern Thailand that particularly affected Chiang Rai and Phayao provinces, LG Thailand launched the “#LGFreeLaundryService” initiative between September 19-30, providing the free laundry service to assist over 1,300 flood victims across three strategic locations in both provinces, helping communities cope with the aftermath of flood-damaged belongings and mud-soaked materials. This initiative exemplifies LG’s core brand promise of “Life’s Good,” demonstrating our commitment to delivering innovation for a better life that extends beyond mere service provision to meaningful community support.
Stay tuned to
link hidden, please login to view to see what other aspects of life the company is revolutionizing around the globe. Contributed by LG Vietnam, LG India and LG Thailand
By Matan Faragi
I'm not sure its the right place but at any case i will describe my issue here and maybe you will be able to help:
Recently I bought a a TV and a sound bar, and i have some issue from the moment i get the TV.
TV model - LG 55LB679Y with latest firmware version i have at my country (Israel) - 04.30.16
SoundBar - LG NB4540
the TV connected to sound bar by "wireless simplink" feature 'LG TV' and TV connected to My Wireless router.
every 5 - 15 minutes, i have sound drops / Cutoff / stooped / Interruption, seem like the TV loose connection to sound-bar for few seconds or something similar, it's happen from any AV source im using HDMI, USB...
and the local re-seller replace the sound-bar to a new one (same modal off course) and i didn't help.
i have try to troubleshot the problem in the last few weeks - but didn't succeed to solve it, and also the support / costumer service didn't have solution for this.
some steps i take when troubleshot this issue:
* different wireless configuration on router - different channels, SSID, Security - issue still persist.
* another wireless router - issue still persist.
* working with optical cable to sound bar - just for testing - working ok, but i need the wireless feature working this the reason i bought sound bar and TV from the same manufacturer.
* disconnect the TV from wireless network - looks like it's working ok, but didn't had chance to test it for long time.
from my point of view looks like it's issue with wireless device on TV not able to to work in parallel with soundbar and wireless network for some reason, It could be caused bysoftware issue on WebOS or Hardware issue with this TV model.
I really hope you be able to help me or throw some light on this case.
Kind regards,
Matan
As the world welcomes in the new year, LG is busy ushering in a new era in TV with the announcement of its new vision statement, “Sync to You, Open to All.” The company’s vision for the present and future of screen is all about syncing the user experience to each user’s individual tastes and lifestyle. It’s a vision that sees the screen as a seamless extension of people’s everyday life; a place where one can go to be entertained, to connect, to pursue their passions and so much more.
“Sync to You, Open to All,” although new, is a continuance of LG’s long-term commitment to changing the role of TV. The company aims to realize its vision by reflecting customer opinion throughout the entire user experience journey, factoring feedback into every single facet – from product and service development to User Interface (UI) features, design and, of course, the viewing experience.
In LG’s reimagining of what television is, the living room TV is now considered a lifestyle hub – one centered on the delivery of a personalized, customizable experience that lets users do and be more.
“Sync to You” relates to the delivery of a user experience that takes personalization to the next level. In terms of hardware, this means the introduction of new and diverse screen products intended for different audiences. These will include screens leveraging Zero Connect technology, to provide spatial and interior design freedom, flexible screens that users can ‘bend’ to their needs and screens that eschew conventional design.
As far as software is concerned, “Sync to You” focuses on providing unique experiences optimized for each user, thanks to webOS, LG’s open and constantly evolving smart TV platform. This encompasses the ability to customize a broad range of functions and settings to one’s preferences, starting with UI configuration, content recommendations and picture quality. But it also extends to the provision of an expanded customer experience, thanks to a wide range of interactive services from categories as diverse as cloud gaming, the metaverse, remote learning, home security, home fitness or health.
A variety of virtual worlds can also be accessed, from
link hidden, please login to view, a virtual art museum allowing you to walk inside and explore emotions beyond the creative work or , the world first TV metaverse service, a full mixed reality platform offering life events that happen at the same time in both realities and , a new cloud solution allowing users to access interconnected digital worlds. The app on LG TVs offer access to over 180 classes taught by the world’s best instructors and thanks to a new partnership with , LG TV owners can benefit from integrated services developed exclusively for webOS.
LG TVs also offer a variety of fitness services from , world’s largest fitness group and , to, which allows to connect a fitness machine to the TV and Exercite, a motion sensor solution that recognizes your body’s posture.
The second part of LG’s vision statement, “Open to All,” is about collaboration, inclusivity and sustainability. Through open collaboration, LG TV users will be able to connect to different platforms and devices across an ever-growing ecosystem. Communication and control will be especially smooth thanks to support for Matter, the latest open connectivity standard for smart home solutions.
LG TV is also designed to be accessible to all users, regardless of their age or abilities. In consultation with its accessibility advisory group, whose members include people living with various disabilities, LG is continuously developing and rolling out inclusive technologies and features. Among those currently offered on LG TV are audio-to-text captions and a sign language screen that can be easily moved and resized whenever the user desires. There are also services available on LG TV that have been created specifically with elderly users and children in mind.
Sustainability is another integral element of LG TV and of LG’s vision. All LG TV products are shipped in boxes that feature one-color printing and have been made from biodegradable materials. The TVs themselves contain parts fabricated from recycled plastics. LG’s OLED TVs deserve special mention when it comes to sustainability, using a smaller number of components and offering greater recyclability than their LCD counterparts. Furthermore, since they do not require a backlight having fewer parts overall, there is less to recycle and dispose of.
Guided by its new vision statement “Sync to You, Open to All,” and a firmly held belief that “Life’s Good,” LG is and will continue to provide LG TV users with differentiated lifestyle experiences and exceptional customer value.
Named ‘Fitness Candy,’ New Company to Deliver Platform Providing Content,
Services and Products for a Fitter, Healthier Life at Home
SEOUL, June 30, 2022 — LG Electronics (LG) and SM Entertainment (SM), a leading entertainment group in South Korea, have launched Fitness Candy, a joint venture that will bring F.U.N – an acronym for First, Unique and New – user experiences to the fast-growing home fitness segment. LG and SM hold a 51 and 49 percent stake, respectively, in the company.
At the official launch ceremony of Fitness Candy, held today in Seoul, Korea, both partners shared their vision for delivering new and differentiated home fitness experiences. Combining their expertise in innovative consumer technology and cutting-edge entertainment, LG and SM aim to create a comprehensive lifestyle platform – complete with content, services and related products – to help people address their health and fitness needs at home.
LG will develop, operate and manage service platforms for Fitness Candy. As a global leader in user-friendly software and hardware solutions integrating advanced AI and data analysis capabilities, it will also be designing a new generation of home fitness devices prioritizing convenience, ease-of-use and F.U.N customer experiences. SM, which boasts a wide global fandom based on its diverse roster of talents, will contribute world-class content to encourage and challenge users of all fitness levels.
Planning and producing home fitness-related content and devices, Fitness Candy will operate via a subscription service-based app. Set to be released in September, the app will be available for installation in various operating systems and devices such as smartphones and smart TVs, providing interactive, personalized services that collect data from smart bands, cameras and exercise devices.
Fitness Candy provides content in six categories: strength training, core strengthening, high-intensity interval training (HIIT), dance, stretching and meditation. Content in each category will run for 10 to 40 minutes and will be updated weekly.
In close collaboration with SM, Fitness Candy is focused on creating content, not only limited to home fitness, that users can easily watch and enjoy. Encompassed by its slogan “Beyond Fitness, Sweet Life,” the company plans to secure a wealth of content such as sports, variety shows and documentaries, as well as content that helps with healthy diets, rehabilitation and stress relief.
The Fitness Candy platform will enable users to access a wide range of interactive fitness content featuring popular Korean celebrities, such as Fitness Candy ambassador and model
link hidden, please login to view, dancer , and actress . Various South Korean athletes, including triathlete , Taekwondo Olympic medalist , short track speed skater and former rugby player , actively participated in the content creation process, enabling the company to provide even more professional and entertaining content to users. The company aims to introduce a variety of new devices that can be linked to its app, allowing users to enjoy content more effectively. One of them is a device that can recognize and track users’ movements thanks to the inclusion of LG’s AI camera and IoT platform. Connecting wirelessly to the user’s TV, the device allows for two-way communication, creating the ideal setup for virtual one-on-one coaching sessions and for participating in live-streamed exercise classes.
Fully utilizing LG’s innovative technologies such as AI, big data, motors and displays, the company also plans to develop products such as muscle strengthening devices, indoor bicycles and smart bands.
“We will transform LG’s business paradigm from function-oriented home appliances into a customer experience-oriented company, transforming into a company that provides smart life solutions to deliver the best customer experience,” said William Cho, CEO of LG Electronics. “Through Fitness Candy, LG’s innovative technology and SM’s content creating capabilities will converge to create differentiated smart life solutions that provide never-before-seen customer experiences.”
“The coming together of LG’s innovative technology and SM’s music, dance and various content that have paved the way for the future of K-pop is a great opportunity for the two companies to contribute to the global fitness and healthcare industry,” said Lee Sung-su, co-CEO of SM Entertainment. “Fitness Candy is a digital fitness content project that goes beyond simple diet experiences and, rather, empowers users to rediscover healthy fitness habits.”
