PreCentral: Add launcher icon shortcuts for Quick-Keys Keyboard
By Joe C
By joe zx
I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
Any advice, thanks.
By netsplit
By svsrama
Sriram.
By Ian_AW
G'day,
Many apps will bring up an alphabetised layout of keys rather than the more conventional QWERTY keyboard.
Is there a way of overriding this so that a conventional QWERTY layout can be used?
Thanks.
