Cannot select Optical + TV output if eARC is plugged in
By Joe C
By Lesbo
By Regis Wheeler
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Peter Steinmeijer
Is my TV too old ?
- 10 answers
- 6,173 views
use tv or sound bar speakers at same time as bluetooth hearing aids
By Ed Kimbrough,
- bluetooth
- hearing aid
- (and 1 more)
- 1 answer
- 7,947 views
- 3 answers
- 7,189 views
- 8,498 views
starwoodtech
3 answers to this question
