Gemini - Browse Photo viewThe Photos app on the TouchPad is great for viewing all the photos on your device (and your synergy accounts), but it's not always the most efficient way to browse or find that one picture you may be looking for.  If you have Gemini File Manager, by Oma Studios, installed on your device, you have another option that may just work for you.
Upon loading up the app, you just need to browse to the folder that you want to view and then either tap on the Gemini Photo Browsing icon along the bottom of the screen or directly tap on any image in that folder. This will bring up a new interface with a large view of the pic on the left side of the screen and smaller images on the right that you can scroll through. Whenever you tap on a photo, you will see the name of the photo on the bottom-right of the screen, along with buttons on the bottom-left to go back to the file manager view or set the photo as your device's wallpaper.
While you don't have as many options as the Photo app in terms of sharing or printing the photo directly from the photo browsing view, you can go back to the file manager view and find the photo again (remember, you can identify the filename, as mentioned above) and the tap-and-hold on the photo to get a pop-up to rename or delete the photo, or get more info where you can email it from there
is available in the webOS App Catalog for $2.99 and is compatible with all webOS devices running webOS 3.0 or higher.
a2t.imgp9cEIGubWbY
    • By Lorenz
    • By MinoDc
      Hi to all.
      What do you think
    • By JayDee
      With so few apps available, I find the need to use the janky included browser. It's bad enough but having to type in my account AND password every time? I love that the apps I *can* download work great -- even when I'm at the end of my data plan and everything is hampered by the slower speed!
      You'd think something called "WebOS" would work with.. the web... a little more reliably. Let us download JioPages, OpenBrowser, SOMETHING that makes our TVs easier to use.
    • By OnlyCORE
      Hey, I have a LG OLED65CX TV (latest WebOS) and  some photos from my Synology NAS are not loading, only in thumbnails like this:
      Most photos work perfectly but some not. They are scans from a photobook and then individually cut in Zoner but that shouldn't matter right? Here are properties of one of the photos
      I really don't know the reason my TV and it makes me really mad since it took a long time co scan these.
      Weird thing is I also scanned other positive film photos and they work great on TV.
      Do you know what might be the problem?
