LG TV keeps logging me out
By Nicola123
By Flavio_S
By Tushar kesarwani
I have purchased a new TV and I'm unable to login to the LG account. Whenever i try i get the error saying : The lg services country information could not be retrieved from the server. Image is attached !
I have registered the TV online on lg.com I tried resetting and rebooting the TV I tried the LG customer service which is pathetic and they just asked to exchange the TV with the retailer ( I don't know what customer service is smoking, if people start replacing TV for every software issue, it will be the end for LG Business) What else can be done?
Tushar
By Nick Payne
Since the latest update to the Binge app on my LG G1 OLED, whenever I try to watch any program on Binge, about every ten minutes or so the app puts up a message on screen saying that it needs to restart to recover memory, and then restarts. And when I go back to the program, the app doesn't remember how much of the program has already been viewed, and starts again from the beginning - I have to fast forward through it to get to the correct point.
None of the other streaming apps I use on the TV - Netflix, Prime Video, Stan, Apple TV - have any such problem, and if I switch to viewing using Chromecast with Google TV, which has the Android Binge app installed on it, I can stream programs from Binge without any such problem.
