PreCentral: Use Save/Restore to backup additional system files and images (homebrew)
Save Restore Misc OS Backup filesThe WebOS Internals' homebrew app
is great to in case you ever need to webOS Doctor you device, swap it out with a new device, or even transfer data between a phone and TouchPad. Typically, Save/Restore will save files that are tied to specific applications, such as progress in your games, specific stock quotes set up in a finance app, or settings/preferences for apps. However, there are a lot of other miscellanous files that you may find throughout webOS that are not tied to specific apps, but you would still like to save. These can include changes that you have made to the or , the background for the phone dialer, or even the database files that contain some system data (e.g. cookies.db, database.db). While you would never want to restore those database files after a device swap or webOS doctor, it would be nice to restore those personalized image files.
Since this is not your typical Save/Restore function and does involve some additional homebrew knowedge, it's not automatically added to the list of supported applications within the app. But, there a little easter egg within Save/Restore that will allow you to backup or restore these files as needed. The easiest way to accomplish this is to use Internalz Pro, by Jason Robatille, which is available in both Preware or webOS Quick Install.
  1. Open Internalz Pro
  2. Navigate to /media/cryptofs/apps/usr/palm/applications/org.webosinternals.saverestore/contrib
  3. Tap on the "org.webosinternals.deviceinfo" script and select "Copy". Find "/var/svc/org.webosinternals.saverestore", highlight it and then choose "Select" to copy it.
  4. Now, you can open up the Save/Restore app, wait for the data to load and choose "Save Application Data". Scroll down until you find "Misc OS Backup files" and ensure that it is toggled to "ON"
  5. Once you run that script, you will have all these files backed up to the USB drive on your webOS device.
  • Be aware that when it comes time to restore these files after a device swap or webOS doctor, you will need to follow the directions above on the new device before you run the restore with Save/Restore in order to add that script to the app on the new device.
If you would like to see what files this script backs up (and have some knowledge of how to read save/restore scripts), you can or you can view it on the .
a2t.imgtLBUflv9uXY
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By WLSI
      I would like to update the OS on a relatively old TV (manufactured in 2015). So there are questions: how to find your version, where to download a new one and check its compatibility with my TV?
    • By dinoc
      I have an LG TV with Web OS 13.30.56 and the HBOMax app was replaced by MAX app.
      Since installing the new app I get 50+ per day ads notifications from Max app with the same add, every day , 50 notifications per day.
      I've made a video with the problem to understand it better:
      link hidden, please login to view Where can I report this problem to get it fixed?
      Please feel free to move this topic to a more appropriate area, if needed.
      Thank you
    • By fmas2
      Hi everyone,
      I´ve installed Kodi on LG WebOS. I need to delete some backups that by default are stored in the WebOS root system. I guess it can be done through WebOS Dev Manager but I´ll appreciate any help giving me the path to achieve such backup folder.
      Many thanks in advance
    • By mahdi alborzi
      I need to update this TV
      Model : 55SJ850V-TA
      Serial number : 707CGKWMJ215
      ESN : LGTV20171=11001816919
      VSN : 1F580793
      Widevine: LGTV17CLGE002389488
