Activate palm ProfileWhen Palm developed webOS, they did a great job of backing up the majority of your settings in the
, such as your App Launcher setup, your synergy accounts, web bookmarks, contacts/calendar/memos entries to your Palm Profile, and more. As webOS progressed from version 1.0.1 to where it is now, the data that was included in your backup also expanded, now including your and some application data if an app developer utilizes that functionality in their app. However, there are few big omissions in the Palm Profile backup, such as saved application/game data and homebrew apps/patches.
WebOS Internals has helped fill that void with the use of the and the "Saved Package List" feature in Preware, and we have documented all the steps you can take to successfully backup and restore your webOS data when you swap or Doctor your device in our . However, there are a few additional steps that you may want to consider taking when reactivating a device to make the transition easier:
    • Before you restore all the packages in Preware's Saved Package List, you should consider installing and configuring App Tuckerbox first. This will add the proper feeds to Preware that will allow you to download any apps from the official App Catalogs that did not auto-download to your device. This will occur if those apps were not compliant with your installed webOS version or were from the beta or web feeds of the App Catalog
    • If you have added some of the advanced scripts to Save/Restore to backup some additional system files or images, you will need to be sure to add those scripts back to your new device before running a "Restore applications" from within Save/Restore.
    • If you had disabled Voice Dial on your old webOS 2.x device, don't forget to disable it again on your new device
  • Restore your Text Assist learned words and shortcuts [webOS 2.x]
    • Unfortunately, neither the Palm Profile nor Save/Restore will restore your or that you added to on your webOS 2.x or 3.x device, but you are able to get a or using Save/Restore.
    • From here, you can manually add that data back into Text Assist on your new device or follow the steps outlined in our tip to use command line to add them back.
    • While your Palm Profile backup will restore your synergy email accounts and most settings, it will not restore any default email folders that you set for your Sent, Draft or Trash folders.
  • Reset Just Type and Exhibition Settings [webOS 2.x+]
    • While and Exhibition mode were two great features in webOS 2.x (and continued in webOS 3.x), their settings were not carried over when you restore your device. Be sure to go into your to enable your preferred Quick Actions and Launch & Search settings, and open up your Exhibition app to .
  • Check general settings
    • Just as with your Just Type and Exhibition settings, your Palm Profile will also not restore every setting on your device. So, you may want to open up the various settings apps to make sure that everything is set to your own personal preferences.
    • For example, open up the to , , or to toggle fast-app switching with a full swipe in the gesture area.
    • Or open up the app and make sure you have the .
    • Continue with the rest of the Settings apps
Got any other suggestions not included above that you follow when you restore your profile onto a new webOS device?
a2t.img8sGGdBzKqtc
    • By bos2prov
      LG Business Cloud Welcomes LG DOOH Ads and LG Pro:Centric Stay,
      Providing More Tailored Options for Diverse B2B Environments
      SEOUL, Jan. 20, 2025 — LG Electronics (LG) will unveil an enhanced version of LG Business Cloud, an online platform that streamlines the management and operation of LG commercial displays and hotel TVs, at Integrated Systems Europe (ISE) 2025 in Barcelona, Spain, from February 4-7. Designed to meet the evolving demands of B2B clients, the platform now offers the LG DOOH Ads advertising solution for digital signage products, as well as the LG Pro:Centric Stay solution for short-term rental businesses.
      LG DOOH Ads provides customers with a comprehensive, customizable and easy-to-use solution for commercial display advertising. Users can set key parameters, such as region, price and ad types, and LG DOOH Ads will automatically select suitable advertisements for display. This reduces the need for businesses to find and secure advertisers themselves. In addition, LG’s advertising solution gives users the flexibility to display ads that they have sourced independently. What’s more, LG DOOH Ads uses advanced AI camera technology to analyze viewers’ data such as gender, age and behavior, delivering customized advertisements based on viewer behavior. It also provides analysis reports on the expected effectiveness of these ads.*
      LG Business Cloud also introduces LG Pro:Centric Stay, a new solution created specifically for short-term rental businesses. LG Pro:Centric Stay complements the existing lineup of software solutions available on the platform, including the LG SuperSign Cloud digital signage content management system, LG Pro:Centric Cloud for hotel TVs and LG ConnectedCare. Tailored for diverse B2B environments, these innovative tools help to ensure greater efficiency and flexibility in signage management.
      Worldwide, LG continues to support major B2B clients with its seamlessly integrated signage software solutions. Mexico-based hospitality company, Grand Velas, employs LG Pro:Centric Cloud, a solution designed expressly for LG Hotel TVs. LG Pro:Centric Cloud simplifies content management and enhances the guest experience, allowing operators to provide personalized information – such as targeted discount offers for honeymooners or shuttle departure times for tour groups – to each room.
      A prominent Spanish telecommunications provider and a well-known U.S. fast-food franchise have embraced LG ConnectedCare, a solution that delivers convenient and intuitive remote display management. Significantly improving operational efficiency, LG’s solution reduces the need to individually adjust each display and enables proactive issue resolution, providing timely email alerts to system managers in the event that a screen error is detected.
      LG’s impressive digital signage software solutions – including the newly-added LG DOOH Ads and LG Pro:Centric Stay – are all accessible through the LG Business Cloud platform.
      “With the arrival of LG DOOH Ads and LG Pro:Centric Stay on LG Business Cloud, companies can now manage their digital displays more efficiently,” said Paik Ki-mun, head of Information Display Business of the LG Media Entertainment Solution Company. “We aim to provide global B2B clients with differentiated signage software through LG Business Cloud, enabling remote display management and personalized content distribution.”
      Attendees of LG’s session at ISE 2025 who verify their subscription to the LG Business Cloud platform will receive an exclusive 50 percent discount coupon for the solution subscriptions.
      * The AI camera-based service, which includes customer behavior data analysis, requires integration with external solutions and incurs an additional payment.
      With Advanced AI Features and Capabilities, 2025 LG gram Laptops Deliver
      Smarter, More Personalized Productivity Experiences
      SEOUL, Dec. 31, 2024 — LG Electronics (LG) is set to unveil its 2025 LG gram lineup, the company’s first on-device AI-powered laptops, at CES 2025 in January. The new lineup includes innovative models such as the gram Pro, gram Pro 2-in-1, gram and gram Book. Leveraging LG’s gram AI technology,1 the latest grams deliver state-of-the-art capabilities and stellar performance, harnessing large language models and personalized AI features to elevate the user experience – all while preserving the series’ iconic slim and lightweight design.
      Enhancing Productivity and Personalization with LG gram AI
      The 2025 gram laptops present a smarter, more secure and highly-personalized user experience through LG’s innovative gram AI. With gram chat On-Device, these laptops utilize AI algorithms to process and analyze data locally without requiring a network connection. At the same time, they provide convenient access to cloud-based AI services via gram chat Cloud, powered by GPT-4o. This subscription-based service, which uses GPT-4o, is offered free of charge for the first year. The integration of on-device and cloud-based AI creates a hybrid AI solution that enhances productivity by delivering personalized insights, a comprehensive knowledge base and an intuitive, ever-evolving experience that adapts to users’ needs.
      gram chat On-Device employs a small language model derived from LG AI Research’s EXAONE large language model. This enables fast and secure local processing to provide relevant answers and simplify device management. Notable features include Time Travel, allowing users to quickly and easily revisit web pages, documents, videos and audio files. Meanwhile, gram chat Cloud leverages vast web-based datasets for detailed and comprehensive responses to user inquiries. Additionally, gram chat Cloud integrates with personal calendar and email services, enabling users to manage their schedule and send and receive emails more efficiently.
      Unleashing Unprecedented Performance with Intel’s Next-Generation Processors
      The 2025 gram laptops set a new benchmark in the series’ history, powered by Intel’s next-generation processors: the Intel Core Ultra H-Series (Arrow Lake) and the Intel Core Ultra V-Series (Lunar Lake). The H Series processors are designed to maximize traditional PC performance, while the V Series CPUs are optimized for AI-driven PC experiences.
      The Arrow Lake-powered gram laptops boast more computing power and improvement in graphics processing, compared to 2024 gram models. These impressive laptops deliver an exceptional all-around performance that prioritizes core PC functionality. The Lunar Lake-powered models come equipped with Microsoft’s “Copilot+” PC functionality, offering productivity- and creativity-boosting features such as real-time video subtitle translation and AI image generation.
      Delivering Innovation and Versatility for Every User
      At the forefront of the 2025 lineup is the LG gram Pro (model 17Z90TR), a laptop that presents the best of performance and portability. Inside the gram Pro’s sleek, slim and lightweight form factor is an Arrow Lake CPU and NVIDIA GeForce RTX 4050 graphics card. This advanced hardware combination enables the gram Pro to effortlessly handle a variety of demanding tasks, from resource-intensive graphic design and 3D-rendering work to video editing and running the latest AAA games.
      The lineup also includes the new LG gram Pro (model 16Z90TS), the first Copilot+ PC in the gram series. Measuring just 0.49 inches thick and weighing 2.73 pounds, it delivers remarkable portability. Another highlight is the 16Z90TR, boasting a 16-inch display and an impressively light weight of only 2.64 pounds. As the lightest model in the 2025 gram Pro lineup, it exemplifies gram’s signature lightweight design while delivering powerful performance.
      Additionally, the highly versatile LG gram Pro 2-in-1 (model 16T90TP) has been recognized with a CES 2025 Innovation Award for its outstanding design and functionality. Offering incredible flexibility, the device comes with a wirelessly chargeable stylus pen that expands and enhances the user experience.
      To expand its U.S. market presence, LG is introducing the LG gram Book (model 15U50T), an entry-level model offering key features and benefits of the gram series at a more accessible price. The gram Book has a 15.6-inch Full HD (1,920 x 1,080) display, expandable storage options, a 720p HD webcam with privacy shutter, and a slim and light design for take-anywhere convenience.
      All new gram laptops support gram Link 2.0, an upgraded version of the gram Link feature first introduced last year. gram Link 2.0 facilitates seamless device connectivity across operating systems,2 allowing users to easily share content and transfer files with a diverse range of PC and mobile products, including iOS and Android-based smartphones. This feature also allows users to handle incoming phone calls directly on their gram laptops, minimizing workflow interruptions.
      “2025 LG gram products, featuring advanced gram AI, are powerful, portable productivity companions that can understand users’ needs, intelligently utilize relevant information, and enhance workflow,” said YS Lee, vice president and head of the IT Business Unit, LG Media Entertainment Solution Company. “LG is committed to delivering premium-quality laptops that harness the latest AI technologies to enable users to do and achieve more.”
      Specifications:
      LG gram Pro 2-in-1 (16T90TP) LG gram Pro (17Z90TR) LG gram Pro (16Z90TS) LG gram Book (15U50T)
      Display Size 16-inch 17-inch 16-inch 15.6-inch Display  WQXGA+ (2,880 x 1,800) OLED WQXGA (2,560 x 1,600) LCD WQXGA (2,560 x 1,600) LCD FHD (1,920 x 1,080) LCD WQXGA (2,560 x 1,600) LCD Brightness (Typ.) OLED: 400nit 400nit 400nit 300nit LCD: 400nit Refresh Rate OLED: 48-120Hz (VRR) 31-144Hz (VRR) 31-144Hz (VRR) 60Hz LCD: 31-144Hz (VRR) Weight 3.08 lb 1,399g
      3.26 lb 1,479g
      2.73 lb 1,239g
      3.74 lb 1,700g
      Size 357.3 x 253.8 x 12.4 ~ 12.9mm
      379.4 x 265.4 x 14.4~15.8mm 357.7 x 251.6 x 12.4 ~ 12.8mm 359.8 x 237.8 x 18.9~19.4mm Battery 77Wh 90Wh 77Wh 51Wh Thermal Mega dual cooling system Fan cooling system CPU Intel® Core Ultra 7 processor / Intel® Core Ultra 5 processor Intel® Core Ultra 9 processor Intel® Core Ultra 7 processor
      Intel® Core i5 processor GPU Intel® Arc graphics NVIDIA RTX4050 with GDDR6 6GB Intel® Arc graphics Intel® Xe® graphics Memory Max 32GB (LPDDR5X Max 8,400MHz, Dual Channel) Max 32GB (LPDDR5X Max 8,533MHz, Dual Channel) 8 / 16 DDR4 (Dual Channel, 3200MHz) Storage Dual SSD (M.2)  512GB / 1TB / 2TB (Gen4 NVMe) 1TB / 512GB / 256GB (NVMe) Audio HD Audio with Dolby Atmos Speakers Stereo Speaker (3.0W x2)
      Smart AMP (MAX 5W x2) Stereo Speaker (3.0W x4)
      Smart AMP (MAX) Stereo Speaker (3.0W x2) Smart AMP (MAX 5W x2)
      Stereo Speaker 1.5W x2 I/O Port 2x USB 3.2 Gen2 2x USB 4 Gen3x2 Type C (with Power Delivery, DisplayPort, Thunderbolt 4)
      HDMI 2.1 (4K@60Hz)
      1x USB 3.2 GEN1x1 1x USB 2.0
      2x USB3.2 GEN2x1, HDMI 2.1 (4K@60Hz)
      Software LG gram Chat LG gram Link
      LG Glance by Mirametrix®
      LG gram Link Webcam FHD Webcam + IR Camera with Webcam & Dual Mic. (face-recognition) HD Webcam w/privacy shutter
      1 Availability of AI features may vary by model.
      2 The gram Link 2.0 supports devices running iOS and Android. The compatibility may vary depending on the device and operating system version.
      “Level 3” CSMS Certification Demonstrates Company’s Capability
      to Ensure Digital Safety of Its Innovative Mobility Solutions
      SEOUL, Dec. 3, 2024 — LG Electronics (LG) continues to bolster its cybersecurity capabilities in automotive technologies, reinforcing its position as a prominent tier-1 mobility solution supplier. The company recently earned Cybersecurity Management Systems (CSMS) certification at Level 3 from TÜV Rheinland, a global testing and certification agency. Recognized as the highest level of certification, this milestone reflects LG’s dedication to ensuring security throughout product development, manufacturing and real-world application.
      The CSMS certification, which confirms compliance with the ISO/SAE 21434 standard and UN R155 regulation, is now a mandatory requirement for automakers in 56 markets. The certification involves comprehensive evaluations, including simulated cyberattacks designed to identify vulnerabilities in security measures and processes. LG’s advancement from Level 2 to Level 3 certification underscores its commitment to meeting increasingly strict cybersecurity criteria, achieved through rigorous testing of both its CSMS standard and manufactured products.
      In line with industry best practices, LG adheres to the Automotive Software Process Improvement and Capability Determination framework, widely known as Automotive SPICE® (ASPICE). Developed by the Automotive Special Interest Group, which includes many well-known European automakers, ASPICE provides a systematic approach to evaluating and improving vehicle software development processes. LG has received recognition for its implementation of ASPICE for Cybersecurity, an extension of ASPICE that includes a number of additional cybersecurity assessments.
      As the automotive industry transitions toward software-defined vehicles, LG remains at the forefront of addressing evolving cybersecurity challenges. In addition to obtaining globally recognized certifications including CSMS and adopting ASPICE framework, LG has strengthened its capabilities through strategic initiatives, such as the acquisition of Cybellum, an Israeli automotive cybersecurity company, in 2021.
      “LG is at the forefront of employing cutting-edge security technologies and processes to deliver safer and more reliable solutions for automakers and end users,” said Eun Seok-hyun, president of LG Vehicle Solution Company. “We will continue to refine our security systems to stay ahead of increasingly sophisticated cyberthreats targeting the mobility sector.”
      LG UltraWide Monitor (model 34BA85QE)1
      Note: This article is for informational purposes only and does not provide medical advice. It is not intended to replace a professional medical diagnosis or treat any medical condition.
      As time spent in front of PCs and monitors increases, so too do health concerns stemming from poor ergonomic settings, such as eye strain, wrist pain, headaches, sore neck and more. A
      link hidden, please login to view indicates that up to 63 percent of office employees experience neck pain,2 inhibiting them from achieving peak performance and remaining motivated throughout the work day. To address these challenges, workers using monitors for extended periods should adopt preventive measures to safeguard their health. Here are some health-conscious practices to keep in mind during prolonged use.
      1. Position the Monitor at Eye Level
      LG QHD Monitor (model 27BQ75QC)1, 3
      To prevent issues such as sore necks and headaches, it is essential to align the monitor to eye level. Traditional monitors typically require employees to adapt to a fixed workstation environment, but with adjustable stands, users can modify the screen’s height and angle, promoting a neutral posture and reducing pain during long work hours. Monitors with ergonomic stands – such as LG business monitors – present built-in adjustable functions like tilt, swivel and 90-degree rotation for a more flexible and comfortable work environment.3
      2. Maintain Optimal Viewing Distance
      Limited desktop space often constrains employees to sit in a position too close to the monitor, resulting in eye strain and neck fatigue. To help maintain an optimal viewing distance – typically an arm’s length – LG business monitors feature a slim stand and integrated power module. This streamlined design saves space, keeping workstations more organized and supporting better ergonomic practices.
      3. Adjust Screen Settings
      To protect eye health, adjustable monitor settings and specifically designed modes are available for individuals who use screens extensively. For instance, Reader Mode on LG business monitors alters the screen’s color temperature to reduce blue light, enhancing legibility to reduce eye strain for comfort and relief during prolonged periods of screen time.
      4. Utilizing Ergonomic Monitors
      LG FHD Monitor (model 27BA560)1
      For environments lacking ergonomic equipment, intuitively designed office monitors can significantly enhance physical well-being and productivity. Following this trend, LG is adding the new ergonomic business monitor to its product lineup, catering to individual preferences with a wide range of aspect ratios and resolutions, from UltraWide to UHD, QHD and FHD.
      The new lineup of LG business monitors effectively enhances the in-office experience with a clean design and ergonomic setup, boosting productivity and elevating comfort for employees to truly enjoy working in an engaging and health-conscious environment.
      To learn more about LG’s business monitor lineup,4 visit .
      1 The image is staged to enhance the reader’s understanding.
      2 Chen X, Coombes BK, Sjøgaard G, Jun D, O’Leary S, Johnston V: Workplace-based interventions for neck pain in office workers: systematic review and meta-analysis. Phys Ther. 2018, 98:40-62. DOI: 10.1093/ptj/pzx101
      3 Adjustability may vary between different monitor models.
      4 The availability or launch date of the product in the images may vary by region.
