PreCentral: Swap your Palm Profile between multiple webOS 2.x phones (homebrew)
This tip is only for devices running webOS 2.x
Activate palm ProfileOne of the most frequently requested features for webOS phones has to be the ability to simultaneously activate your Palm Profile on multiple devices and swap between phones as necessary. This ability was added to webOS 3.0 on the TouchPad, but does not exist for webOS phones. So, if you were ever to activate an existing Profile on a second webOS phone, it will send a wipe command to the original phone and you need to re-activate it from scratch when you want to return to that first phone. You can use some homebrew trickery to
of the device by removing your profile from it, but what happens if you want to go back to that phone later on? Having to perform a full activation of the device is not a good answer.
Thanks to the geniuses as WebOS Internals, you can use those steps mentioned above to prevent your device from being wiped, and then extende it to activate your Profile on multiple devices without requiring the need to erase and re-setup your phones each time you need to swap. It may not be the most elegant solution, but it works, albeit with a few caveats that you should review below. In order to swap profiles between devices, you will need to have the homebrew app installed on your device and take advantage of two previous PreCentral tips: and the aforementioned .  Continue after the break for directions on how to set up your devices and swap your profile between them.
a2t.img8lGeZ7MYYfI
    • By David Daul
